higher boost with stock pulley?
Also, for anyone having issues with this, if its not the cat check to make sure your intercooler pump is working. I've seen a few cars with connection problems, where the plug wasn't in all the way from the factory. Look in the little fill neck with the car running, you should see coolant flowing across the bottom.
