The Highest Redline?
Old Apr 27, 2006 | 08:29 PM
FLCobalt's Avatar
what is the highest redline you see out cars running in the future? like 7500? 8000 possible? or is 7000 the highest we can safely run.
Old Apr 27, 2006 | 08:33 PM
Nuclear's Avatar
its hard to say, if there are more stage kits after 2 then yes
Old Apr 27, 2006 | 08:38 PM
NightmareRacing's Avatar
Usually, you want to stay at about 4000 to 4500 feet per minute on your piston speed (4500 and up for good forged pistons). So if you know the stroke of the motor you can calculate piston speed, and go from there...
Old Apr 27, 2006 | 08:48 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
The 300+hp build shows a dyno of 7850rpms (this is what I am aiming for) I have also seen a dyno showing 8300rpm's (i am not positive but I think it was for the Cobalt they used on the Bonnyville Flats) so as long as your willing to pay to upgrade we have a ways to go yet.
Old Apr 27, 2006 | 11:39 PM
selfinfliction's Avatar
you can safely run 14,000 rpm..... you just have to have the money to invest in the proper equipment... but remember higher rpms aren't always better
Old Apr 28, 2006 | 12:51 AM
Blown 4-banger's Avatar
im not sure about 14,000. We have a 2 litre 4 cylender, F1 cars have like 2.5 litre V-10's! so the pistons and stuff are like as thick as your thumb, so its alot less mass moving with each piston.
Old Apr 28, 2006 | 05:59 AM
cavy9psi's Avatar
you dont wanna rev high anyways....lose of a lot of power when u start reving high...honda's rev high=no torque...yea you get top end but you still make less and less power....stick to 7k max id say even 6500 what the car was designed for unless you start changing out heads...then 7 but no more
Old Apr 28, 2006 | 06:14 AM
that's exactly what i said.. with enough money almost anything can be done
Old Apr 28, 2006 | 09:19 AM
BLKSS's Avatar
I can see them running 8000 without any problems.
Old Apr 28, 2006 | 10:10 AM
I believe the Renault V8 (yes V8) f1 motor was turning 18,000 plus (yes they stoped showing the rpm past 18) and idle at 5000...800hp and 400ft lb ...
Old Apr 28, 2006 | 09:05 PM
I thought you were saying that the ecotec could go to 14,000 not just any motor
Old Apr 28, 2006 | 09:27 PM
Cobalt_Supercharged's Avatar
I talked to a mechanic at the dealership today and he talked to Engles, I think it was. They helped with the design I guess. The weakest point is the valve springs. The mechanic I spoke with already installed better ones on his SS S/C. I think his are good to 8,000 rpm.
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
Sep 28, 2015 12:51 PM
footballplaya3k
Sep 28, 2015 11:14 AM
SlowSaturn
Sep 28, 2015 11:03 AM
Silverbullet333
Sep 22, 2015 10:55 AM
