Hitting the Rev Limiter to Hard-
Old 12-25-2006, 09:51 PM
SSinPhilly's Avatar
I have been having Clutch Problems and the car wont go on until it slams.....it seems like the clutch is seized or somthing so it has to bang loose than drives like normal....the night before i had this problems i sorta hit the rev limiter hard. What could hitting the REV LIMITER hard of done to my car? Thanks
Old 12-25-2006, 09:52 PM
Get low
biohazard's Avatar
if you shifted as u bounced the limiter it could have busted a synchro
Old 12-25-2006, 10:51 PM
Blown 4-banger's Avatar
You don't usually hit the limiter while shifting. I missed third and reved to 7800 rpm and didn't hit the limiter.
Old 12-25-2006, 10:53 PM
Rangerondubz's Avatar
WOW 7800 rpm's isnt that alittle to extreme for our valvetrain? Well I guess I just answered my own question if your's reved that high lol, im sure it cant be good for long periods of time.
Old 12-25-2006, 10:55 PM
Ljavy17's Avatar
sounds like a syncro
Old 12-25-2006, 10:56 PM
SSdan's Avatar
How could hitting the limiter and shifting bust a syncro?
Old 12-25-2006, 10:57 PM
SSinPhilly's Avatar
Ok I did be an ******* and i bounced the limiter for a good 3 seconds. Which leads to my problem....ocassionally the car will have to do a massive slam start and then kick over and be fine. Also sometimes i start it in Neutral and the car will not go into any gear which will have to turned off and then bang started as stated above. WTF is my problem?? Also I had my stage 2 for 3 days...........night time bounce the rev limiter..........morning start car wont go into gear.
If its a syncro how hard is that to be fixed or replaced?
Old 12-25-2006, 11:14 PM
selfinfliction's Avatar
that's awesome lol
if the engine is under a load running up those higher rpm's aren't as bad... bouncing it off the redline under no load for 3 seconds on the other hand......
Old 12-25-2006, 11:19 PM
amomentsnotice's Avatar
3 seconds is a REALLY long time!!
Old 12-25-2006, 11:33 PM
SSinPhilly's Avatar
im a ******* idiot what can i say..........i must like to waste money!
Old 12-25-2006, 11:35 PM
SSinPhilly's Avatar
i sorta dumped the clutch and spun hit 2nd and bounced it off the limiter....... i was in such a rage bc someone drove buy and lauched a bottle of soda at my car.
Old 12-25-2006, 11:37 PM
oh well in that case i understand. some one did that to me once and i almost hit them.
Old 12-26-2006, 05:46 AM
i don't think i would've done that...our cars are decently fast, you could've just chased the guys down and beat their ass... and if you don't think you would've won... you shouldn't have chased them down
Old 12-26-2006, 11:29 AM
SSinPhilly's Avatar
it was raining and they were in a evo so go figure.
Old 12-26-2006, 11:41 AM
Get low
biohazard's Avatar
not that hard..... u hit the limiter so obveously your at extremly high rpms... and u usually hit the limiter right before u shift if u hit it so ur shifting into the next gear at a very high rpm thus killing your synchro lol
Old 12-26-2006, 11:43 AM
SSdan's Avatar
Kind of like powershifting without taking your foot off the gas? Sometimes when im really not paying attention ill hit the limiter and then shift.
Old 12-26-2006, 03:09 PM
SuperCobaltSS's Avatar
What happened to my car when i got my 2.8 is that i bounced off the rev limiter a few times and broke the springs on the clutch plate and it wouldnt stay in gear nor would it go into gear. Could be your clutch plate.
Old 12-26-2006, 03:34 PM
SSinPhilly's Avatar
yeah im just going to buy another clutch and a findaza plate instead of the whole flywheel. It will be better than resurfacing it. NOW, what clutch should i get now that im upgrading to the stage 3?
Old 12-27-2006, 12:45 AM
ReMz's Avatar
3 seconds... a figure of speech? cuz im trying to imagine myself doing this with no luck
1....... ....... VROOM VROOM VROOM VROOM
2...... ....... VROOOOOOOOM VRRROOOOM (SHIFT U IDIOT)
3..... .... ...... I GIVE UP! SHIFT!!!!!
*shift*
BOOOM!
Old 12-27-2006, 11:05 PM
SSinPhilly's Avatar
maybe it wasent that long but **** it happened and i need to figure out wtf it did
Old 12-27-2006, 11:20 PM
Boosted_SS's Avatar
dude just do what i told you in the PM when you messaged me yesterday! take it to the dealer and tell them to look at it but tell them you do not authorize them to do anything that will cost you $$$ or could potentially cost you $$$ to put it back together if the determine it to be abuse or a clutch failure. instead of sitting here whining about it take it to the dealer and get it over with.
biniecki
10-25-2015 02:23 PM
Iceberg
09-29-2015 12:33 PM
Iceberg
09-28-2015 01:31 PM
z28addiction
09-28-2015 12:03 AM
DocSvensk
09-27-2015 02:24 PM
Quick Reply: Hitting the Rev Limiter to Hard-
