Hmm...Meth ... maybe so
Old Aug 3, 2009 | 02:57 PM
  #51
Snakes709's Avatar
u only wish u were famous..lol. And man..4hp? thats awesome!...wish i could get 4hp more!. lol. So basically 1* = 1hp...sweet. If i want to get my car to 400hp i only need to go to 100* of timing...well im at 24* so iiunno, to tired to do math
Old Aug 3, 2009 | 03:12 PM
  #52
freakta's Avatar
im pretty sure my car kept adding timming up top. im running iat2s alittle above iat1s to a little below iat1s so its loving the cool temps. im talking single digit numbers here
Old Aug 3, 2009 | 04:37 PM
  #53
WickedSS2005's Avatar
Don't use washer fluid.... Fill up a 5 gallon tank w/ 3.5 gallons of methanol, and 1.5 gallons of distilled H2O. I'll fill you in on it tomorrow while we install and tune
Timing abovew 26* does not add power. It's a waste
Last edited by WickedSS2005; Aug 3, 2009 at 04:37 PM. Reason: Automerged Doublepost
Old Aug 3, 2009 | 04:48 PM
  #54
04redline0124's Avatar
Well if anyone is interested, I am selling my Labonte Motorsports stage 3 meth kit, with larger 1 gallon tank, Failsafe (safety for the car), and Boost Bypass Kit (also safety). I am only asking 450 shipped OBO and it is 625 new for all these options, and ive only had it on the car for a month.
  #55
venum_us_2002's Avatar
Originally Posted by bwalker0510
hmm i wonder how much whp i could pick up on a stronger mixture like 75/25.
i was just thinking that, im running straight windsheild washer fluid. If i just dump in a 75/25 would i need a retune? or would i make more power with just the mixture?
/thread jack
Old Aug 3, 2009 | 05:05 PM
  #56
383_Stroker's Avatar
/thread jack
You're go rich if you just up the meth mix.
Old Aug 3, 2009 | 05:53 PM
  #57
lsjwannabe's Avatar
Your in good hands
Pm me with any questions
Old Aug 4, 2009 | 12:56 AM
  #58
06_SIC_SS's Avatar
so in other words he should get retuned? im pretty close to purchasing the base kit..say a check vlave fails or sticks open or shut..how do i fix it? just remove the nozzle and clean? or what...also.. if im running..13 degrees of timing..and i bump it up to 18ish with meth..how much power am i gonna see from that? say im at 310 to the wheels with full exhaust,TVS,2.9 pulley, and a tune on 13 degrees of timing..and i get meth and get tuned to 18 to 20 degrees of timing..could i see 330whp? theoretically.. i know every car is different and im actually more interested in the cooler intake temps than even more power right this second but im really curious to see how much it could add..
i dunno if anyone has dynoed from 13 degrees to maybe 20 to see the difference but if i had to guess u could feel a difference..
Old Aug 4, 2009 | 09:32 AM
  #59
Snakes709's Avatar
if something fails or breaks....take it out clean it. If it doesnt work, send it back if its coverd under warrenty. I'm hoping that was a example hp u have cuz theres no way u r at 310...lol. Maybe 260-270 without meth. From what i've been told...i could be wrong tho. Around the 17-23*timing mark...each * of timing gives u approx 10whp. Higher u go the less hp u get cuz 25* is the drop off. Either way u if start at 13* and then go to 24*...u will see a big difference.
Old Aug 4, 2009 | 09:54 AM
  #60
scott allen's Avatar
i made 290 whp on the stock pulley and no meth.and that was on a mustang dyno.i see him making 310 whp with a 2.9 pulley . no reason why it wouldnt.
Old Aug 4, 2009 | 10:21 AM
  #61
Um. TVS dude
Old Aug 4, 2009 | 10:40 AM
  #62
10whp with each degree, so from going from 15 to 20 he will gain 50WHP!?!? highly doubtful
Old Aug 4, 2009 | 11:11 AM
  #63
Snakes709's Avatar
Originally Posted by WickedSS2005
Um. TVS dude
umm i know dude, i own a tvs also. But u cant make 310 without meth and only at 13* or around that of timing. Once on meth and up the timing to 24-25* then yea, he can make that
i said approx not exactly 10whp
like i said above...no meth and only at 13* of timing, doubtful he is at the much power
Old Aug 4, 2009 | 11:12 AM
  #64
06_SIC_SS's Avatar
umm i know dude, i own a tvs also. But u cant make 310 without meth and only at 15* or around that of timing. Once on meth and up the timing to 24-25* then yea, he can make that
i walked my buddies srt 4 with 290 to the wheels pretty good..i hope im at 310 and it is a smaller pulley...either way...it feels strong lol even if i am lower than whats believed if i up my timing to near 20 u think ill see possibly 20 hp?
Old Aug 4, 2009 | 11:15 AM
  #65
Snakes709's Avatar
if u go from 13* to 20*? yea 20hp is possible. Just curious what other cooling mods do u have? I cant remember. I have meth, CA Heat Exchanger and 2 Step Colder plugs....got mine at 24* and no knock and low iat2. If u get meth and a few other cooling mods u can put more timing and get the most power u can. Also with the cooling mods u can play around with the AFR which also helps. Mine is at 11.9...well now its probably around 12.3-12.5 cuz i just installed header/dp/exhaust. So i have to change my tune. But yea...u r going to see a big improvement once u tune with a meth kit.
Also remember...always under-estimate what u r guessing u have for hp. 9 times out of 10 u will think u have XXXwhp but u will have like 20whp less...also depends on the dyno. When people ask me how much hp i have. Since i havent dyno'ed yet i say "hoping to be at or over 300whp. Then again....dyno numbers r dyno numbers....1/4 is where its at....or autox if thats your poison
Old Aug 4, 2009 | 11:20 AM
  #66
06_SIC_SS's Avatar
awesome.. im excited..and i have 2 step colder ngk plugs and i have the ottp heat exchanger which may i add is massive lol .. the thing took a **** load of coolant lol .. and im currently tuned to mid 11s in the afr.. i feel like im at a point where the car has a lot of potential now..with some meth and maybe a ported head with some cams to match
very good point..thats actually the exact words i say lol it does feel like im at 300 though..especially with meth comin up..
Old Aug 4, 2009 | 11:23 AM
  #67
lsjwannabe's Avatar
I made 313 on pump gas and 16*. Smaller pulley but it can be done.
Old Aug 4, 2009 | 11:24 AM
  #68
06_SIC_SS's Avatar
with or without meth
Old Aug 4, 2009 | 11:26 AM
  #69
Todd, I'm still certain I can pull more out of it than what you just got done. 13* is weak lol
Old Aug 4, 2009 | 11:27 AM
  #70
lsjwannabe's Avatar
pump gas, hence no meth.
Old Aug 4, 2009 | 11:28 AM
  #71
06_SIC_SS's Avatar
easy smart ass lol
and im pretty sure i ended up at 13* ... it feels damn strong though
Old Aug 4, 2009 | 11:31 AM
  #72
ei3dag3's Avatar
ais said i could take 32 deg windshield washer(i'm in tx) , and for every gallon of that mix 4 bottles of heet. and that'd be a 50/50 setup.
right now im doing 30/70 thought since im not on a tune
it costed next to nothing. if they say its okay, then i'm willing to bet they know what they're talking about
Old Aug 4, 2009 | 11:32 AM
  #73
lsjwannabe's Avatar
easy smart ass lol
Yeah there is more you can throw at it for sure depending on how lean your running. I could get 18* all day on 93 oct and 25 psi, i just dumbed it down for the dyno.
Old Aug 4, 2009 | 11:34 AM
  #74
06_SIC_SS's Avatar
afr is low to mid 11s
Old Aug 4, 2009 | 11:38 AM
  #75
lsjwannabe's Avatar
Yeah you should be able to go another 4* easy on pump gas
