Hooray, first CEL.
Old Jun 9, 2006 | 02:45 PM
ajent's Avatar
Hooray, first CEL.
First happened yesterday, all I have is stage 2, injen cai. Other things like strut bar I don't think need to be mentioned.
Anyways, only seems to happen when I really get on it after work. Yesterday I pull out of the parking lot and onto the long straight away like i'm trying to escape a tornado, before I was out of 2nd gear the CEL came on. I got home and did the battery trick and it went off.
Babied the car to work this morning and all is fine. Just got off work, and again pulled out of the parking lot and did the same thing, and got the same results.
Not sure what's making it pop up, maybe I need to look around the forums and find out how to make a code display?
(Premium Gas being used as it has been for the whole 9,000 miles on the car).
Old Jun 9, 2006 | 10:11 PM
quad4racer's Avatar
are you letting the car warm up before you get on it?
Old Jun 9, 2006 | 11:18 PM
snowcrash's Avatar
Welcome to the CEL club! Membership is free (not including the cost of a CAI)
Old Jun 10, 2006 | 02:37 AM
sscobalt06's Avatar
I get CELs all the time. I usually get them when it rains tho.
Old Jun 10, 2006 | 02:41 AM
Vaughts05ss's Avatar
Well ive got a cel because my car is throwing a lean code..Oh and my car is completely stock
Old Jun 10, 2006 | 02:54 AM
sscobalt06's Avatar
I think that I was getting a CEL because I took a look at my intake the other day and the screws were missing from the MAF sensor, it was just sitting there. You might want to check that.
Old Jun 10, 2006 | 02:57 AM
2006ArrivalBlueSS's Avatar
NGK BRK7E Plugs = no CEL - try them - they work!!
Old Jun 10, 2006 | 04:11 PM
ajent's Avatar
Sorry I've been away for a while.
Yeah, this time the CEL just went off on its own.
the 1st CEL occurance I didn't let the car warm up, the 2nd I let it warm up for like 20 minutes.
Thanks for the reccomendation for plugs, maybe i'll try those.
Old Jun 11, 2006 | 05:50 AM
sunfirejoe's Avatar
i tried the plugs lol, and it made the cel come on, lol, i had pending code po170 runing rich than i went to po171 which is lean lol
Old Jun 11, 2006 | 10:03 AM
2006CobaltSS/SC's Avatar
Instead of pulling the battery cables try pulling the PCM Fuse in the underhood fuse panel for 5 minutes. It will completely clear the adaptive memory of the PCM only and you wont have to reset all the radio and other memory functions. If you dont wait the full 5 minutes you will have some codes retained which will cause another CEL.
Old Jun 11, 2006 | 12:45 PM
savior's Avatar
sunfire, what did youy gap your plugs at
Old Jun 11, 2006 | 03:59 PM
sunfirejoe's Avatar
gapped them at .37 i think im gonna go to .40 tonight, it only goes lean when sitting at a set of lights
Old Jun 20, 2006 | 12:46 PM
ajent's Avatar
Ran the code, its:
"P0103
MAF or VAF
A Circuit High Input"
Old Jun 20, 2006 | 01:03 PM
torrin1234's Avatar
yea. probably should check the screws as mentioned by sscobalt06.
I can't wait to join the CEL club! haha my cai arrives the 21st
Old Jun 20, 2006 | 01:07 PM
OniMirage's Avatar
hey are you guys flipping the lights on and off after unplugging the battery to insure the voltage is all gone?
Old Jun 20, 2006 | 06:17 PM
ajent's Avatar
Cool, will do this weekend. It doesn't seem to come on until 7,000 rpm's.
The people at discount auto parts used their hand held reader to re-set it, so it's not on now, Will still check though.
Old Jun 21, 2006 | 02:20 AM
Black SS's Avatar
Same code I got-same situation. Its because the sensor is only meant to read up to like 10,000 or 11,000 Htz. Any more and it throws a code. GM service manuals say to check for water in the intake because it can make the sensor read high. It is your cold air intake that is doing it. It just flows too much cold air and might allow a slight amount of moisture to accumulate on the sensor.
Old Jul 1, 2006 | 10:45 AM
ajent's Avatar
Discussed in https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/after-stage-2-car-falls-flat-its-face-when-shifting-21928/
but an update for anyone that reads, my injen filter was laying on its side, (thankfully didn't fall off of the plastic bottom and out on the road), but I attached it back to the tube, and it got rid of: choppy acceleration, car almost stalling when shifting to 2nd and 3rd the 1st time in the morning, and no more check engine light at 7k rpms.
Old Jul 1, 2006 | 10:50 AM
06CorvaltSS's Avatar
Discount auto parts??? I think that would be the last place I would be dealing with.. Is that the name of the store??
Old Jul 1, 2006 | 12:18 PM
ajent's Avatar
yeah, it's like auto zone. and I learned from them giving me the wrong spark plugs not to go to them anymore.
Cobalt08LS
Jun 19, 2016 07:29 PM
jcarroll53
Sep 24, 2015 07:43 PM
Nightwatch08
Feb 11, 2008 09:57 PM
06blackSC
Jun 21, 2007 01:27 PM
