Hopefully a simple LSJ/LNF T-Chain Tensioner question...Please?
Old Dec 5, 2011 | 11:17 AM
bonylad's Avatar
I read the how to, and noticed some of you guys have said to get the new one from CED that the LNF's come with (hydro). The OP who made the how to had to remove the valve cover, while some other members have said.....simply remove the old one (old lsj) and reinstall the LNF (hydro)....as simple as removing it by unscrewing it.
Is this correct? I have had a noise under hood and this morning a rattling noise which I think is the tensioner. Anyone confrim?
Old Dec 5, 2011 | 11:21 AM
mrbelvedere's Avatar
yea it probablt is the tensioner you dont have to remove the v cover but i would and use some zipties or small rope to take up the slack in the chain the reason i say this because if the chain has alot of slack in it is there is a chance it can jump time when the old tensioner jumps out (it happened to me)
Old Dec 5, 2011 | 01:19 PM
bonylad's Avatar
how? if im not taking off the v/c....how will i access the chain?
Old Dec 5, 2011 | 01:23 PM
read and comprehend what i said
you dont have to but i would
Old Dec 5, 2011 | 01:26 PM
i just bought the 'updated' design one for the lsj. 1"1/4" bolt on the passenger side rear of the engine near exhaust manifold. unscrewed it, put the new one in.
Old Dec 5, 2011 | 02:53 PM
bonylad's Avatar
I misread.......Im not stupid sir. **** happens.
Sweeeeeet. Thank you sir.
Old Dec 5, 2011 | 02:57 PM
:css:
Old Dec 5, 2011 | 03:30 PM
bonylad's Avatar
:css:
Old Dec 5, 2011 | 04:08 PM
Originally Posted by bonylad
I misread.......Im not stupid sir. **** happens..
i never said you were stupid atleast you looked for a soloution to solve your problem before you asked for more information
Old Dec 5, 2011 | 06:02 PM
cavfiredesire's Avatar
How would you go about tying it to make sure it doesnt skip?
Old Dec 5, 2011 | 10:44 PM
you can use long zipties or small rope and wrap it from the ex side of the chain to the int side to make sure the slack dosent come into the chain when you remove the tensioner if the chain is realy loose it will jump when you remove it due to the fact that the tensioner will jump out of the head from being spring loaded (the updayed tensioner will do the same when unscrewed) when it gets all the way to the end of the threads
Old Dec 8, 2011 | 12:42 PM
bonylad's Avatar
Its hard to get across emotion on the interweb....it was kinda a lol im not stupid dang kinda thing. Either way....
+1 for just removing it and installing it with no v/c removal. I did take the advice offered elsewhere about bumping the engine 3-4 times with out actually starting it to make sure it didnt bind...and to "set" everything. Started up and runs fine!
Thanks all who helped!
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
ThoR294
Oct 4, 2015 08:44 PM
justinchinn
Oct 2, 2015 12:18 PM
