How accurate are the performance #'s on the Interceptor?
I just got my interceptor put in last week, and finally had a chance to do a few standing launches with the performance readings being taken. Got anywhere from a 14.68 @97 when I missed 3rd to a 14.11 @ 101 on my best run. I know that they're not going to be 100% accurate, but seeing as how I'm 4 hours from a full 1320 track and have to work weekends, I'm slightly boned on getting some real track times until at least next summer. I was just curious as to if some of you guys have run those when you were running on a timed track, and how the times compared?
Originally Posted by ballerSS
I tried mine after getting stage 2 installed and got a 13.55 @ 106. I'll be going to the track this weekend and I'll use it and compare to the track times. I'll let you know.
Originally Posted by roccityroller
depending on what you have done...that's about right
My peak HP #'s on the interceptor run about 225, and that seems a tad high stock too. I may have a beast from the factory, but I'd guess both those numbers are a little inflated.
I've been getting low 14's at 104 mph pretty consistent using my interceptor, but my car is bogging bad in 1st and powershifting 1st to 2nd. I did notice my O2 sensor reading is all over the place, jumping around anywhere between 10 to 800 at any given time in any given condition. Don't know anything about tuning, but this concerns me, shouldn't it be a somewhat consistent number?
I am glad to see the Ingalls Stiffy is helping with the 60 foot times. With forced induction anything that can be done to get power to the wheels for less than 200 bucks is a GREAT deal. I would recomend a tune to extract the most power possible, sometimes there is a lot of un-taped power waiting to be released
my 60 fts got worse. and another person i know has had the same effect.
yes there is no wheelhop, but my 2.3 60's with wheel hop went to 2.5 2.6 all spinning.
but the gauge sounds pretty close. Mine is just about right on.
i dont think the interceptor compensates for wheel spin so if you have any spin at all even a chirp it is going to be off by a good number or two but at the same time your on tougher road than that of the track so your traction will be better.
