How do you take off intake manifold?
Old Jan 29, 2011 | 06:23 PM
chrisjaldin's Avatar
I'm trying to install here dual pass end plate and from what I read; its pretty easy. But, I'm stuck here trying to get the intake manifold off. I already pull of 5 bolts and 2 hex nuts, also the bolt that holds the oil check line. I'm prying off the from any angle possible putting a flat screwdriver against the engine block but its coming out slowly and still very hard. I'm missing a bolt or something? How did you guys take it off? Thanks for the input.
Old Jan 29, 2011 | 06:37 PM
Old Jan 29, 2011 | 06:41 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you're missing a bolt. there are 8 that hold the intake manifold on. one is hiding pretty good behind the alternator
Old Jan 29, 2011 | 06:42 PM
05Slowline's Avatar
there is a bolt at the bottom left side of it if your facing the motor
15mm i think not sure, put your hand down the left side feel around and you'll get it, take the alternator off also to get it easier
Old Jan 29, 2011 | 07:06 PM
ok. thanks. I'll go and see now
Old Jan 29, 2011 | 08:37 PM
05Slowline's Avatar
I think you gotta unbolt the dipstick too makes it easier or something at least i did it was almost 2 years ago though so kinda fuzzy details hahah
Old Jan 29, 2011 | 10:51 PM
Leafydialupking's Avatar
Isn't there also supposed to be a support bracket bolted to the bottom of the intake manifold. i never ran one and the kit I installed didnt have one but the instructions mentioned it.
Old Jan 30, 2011 | 09:56 AM
05Slowline's Avatar
read post 4
Old Jan 30, 2011 | 11:22 AM
I take off sucessfully but to my suprise I found this:
Its oil inside the manifold and in the laminova cores also. This is way my intercooler coolant was milky white because it was mixing with oil. Where should I search first to see cracks or leaks. That yellow plastic I took a photo of, maybe is broken and that seems to carry oil.
Old Jan 30, 2011 | 11:32 AM
05Slowline's Avatar
damn that's shitty that im should be bone dry inside no coolant or oil idk where you would start to find the culprit though haha
Old Jan 30, 2011 | 11:33 AM
whoa. Could that be from all the oil in your intake manifold just getting blown past the seal on the end plate and into the coolant? And what the heck are those to two pictures? inside the ports on the head?
Old Jan 30, 2011 | 11:35 AM
05Slowline's Avatar
should be nothing in the im to begin with lol
It seems like everyone gets oil in there. I do too when I forget to empty my catch can and it starts siphoning oil in.
Old Jan 30, 2011 | 11:41 AM
05Slowline's Avatar
......never should there be oil, coolant, or anything else inside the im, if there is you have a problem. the im should always be bone dry.
Old Jan 30, 2011 | 11:48 AM
BLAZIN07SS's Avatar
I'm too JDM for you
With the stock breather system you will always have oil in the intake manifold. Never seen that much on the cores though
Old Jan 30, 2011 | 01:06 PM
So, with a oil catch this will be solved?
Old Jan 30, 2011 | 01:16 PM
05Slowline's Avatar
Iunno, mine has never had anything in it
Old Jan 30, 2011 | 02:24 PM
I should clean it with just water? I'm also looking forward to port runners
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
