How do you unplug the plug on the fuel rail???
Old Feb 22, 2009 | 04:37 PM
blackss2.0's Avatar
Old Feb 23, 2009 | 04:06 AM
HunterKiller89's Avatar
...what plug?
Old Feb 23, 2009 | 10:32 AM
Red07Coupe's Avatar
1. Remove the coolant overflow pipe.
2. Relieve the fuel system pressure. Refer to Fuel Pressure Relief.
3. Use a back up wrench on the fuel rail and disconnect the fuel supply pipe.
4. Remove the fuel rail attaching studs. Important: Use care when removing the fuel rail assembly in order to prevent damage to the fuel injectors electrical connector terminals and spray tips.
5. Remove the fuel rail using the following procedure:
1. Pull the fuel rail back and upward to remove the fuel injectors from the cylinder head ports.
2. Rotate the fuel rail in order to position the injectors downward.
3. Remove the fuel rail.
4. Disconnect the fuel injector harness connectors
5. Remove the fuel injectors
Are you talking about the injector plugs?
Old Feb 23, 2009 | 10:34 AM
PhantomSS's Avatar
just disconnect the bolt from the fuel rail and the 2 10mm bolts tying it down, then pull up.
Old Feb 23, 2009 | 10:39 AM
Red07Coupe's Avatar
But you have to unplug the harness at the injectors or the main harness to pull it up all the way. I disconnected mine at the injector.
Old Feb 23, 2009 | 10:40 AM
PhantomSS's Avatar
no u dont.
i always took off the injectors after pulling the rail up. even the pic u posted shows it
Old Feb 23, 2009 | 10:43 AM
Red07Coupe's Avatar
no u dont.
No, the pic shows the rail coming up with the injectors. Plus I wouldn't want my injectors contacting the engine or being exposed stuff like dust, dirt and the elements. Its alot easier to remove the injectors if they come up with the rail.
Old Feb 23, 2009 | 10:46 AM
PhantomSS's Avatar
k u say one thing but do another?
YOU DO NOT NEED TO DISCONNECT THE HARNESS.... NUFF SAID PLS STFU.
Ive done it TWICE (installing 42s and putting it back to stock) without disconnecting the damn thing. it lifts WITH it.
Old Feb 23, 2009 | 10:47 AM
Killa SS's Avatar
^ LOL
Old Feb 23, 2009 | 10:52 AM
umrdyldo's Avatar
Slow down people. It's getting hot in here.
Old Feb 23, 2009 | 10:53 AM
Killa SS's Avatar
so take off all ur clothes.
Old Feb 23, 2009 | 10:54 AM
PhantomSS's Avatar
i just hate misinformation and can just picture someone trying to get the harness off each injector while cursing that blue safety clip under the fuel rail at each harness point. Make your life easier, lift the thing, flip it over, and unclip with ease.
Old Feb 23, 2009 | 10:59 AM
Red07Coupe's Avatar
no, you do not need to disconnect the harness to simply change an injector....... but it just makes it easier to have the rail on a table in front of you instead of working off a valve cover where things can fall and get lost or damaged in an engine bay. Plus this guy sounds like he needs to remove his rail for some reason, so thats the info I gave him.
Take a breath buddy and count to 10, stop taking this stuff as an insult of some kind and bringing in all this drama
Old Feb 23, 2009 | 11:04 AM
PhantomSS's Avatar
hey whatever makes it more rewarding for you. i dont see how you can lose clips and harnesses when it is attached as one unit.
lol idc im just picturing it as funny.
Old Feb 23, 2009 | 11:05 AM
Killa SS's Avatar
aww, i thought we were singing nelly. i guess not. you guys are party poopers. im all happy and excited about my car being finished and ya'll are like,blah. lol. wut eve bitches.
Old Feb 23, 2009 | 11:12 AM
PhantomSS's Avatar
hahn kit is ftw?
Old Feb 23, 2009 | 11:15 AM
Red07Coupe's Avatar
no offence to you man, I see what your saying and I see how your method would work. Its just a chance you take when you cut corners. I'm an aircraft mechanic with the Canadian Air Force and i'm trained to think this way.
I've had to replace my injectors twice and I already broke a rail and I've removed it completely everytime. its just 2 more minutes of work and your chances of not losing or breaking anything goes up substantially.
Old Feb 23, 2009 | 11:20 AM
PhantomSS's Avatar
im not even going to ask how you broke that rail.... heh.
Anyway whatever works.
Old Feb 23, 2009 | 11:26 AM
Killa SS's Avatar
hahn kit is ftw?
FTMFW!! hehe
Old Feb 23, 2009 | 12:01 PM
Red07Coupe's Avatar
I never said that I broke it, not that its any of your business..... stop being a ***** man and stick to the topic
Old Feb 23, 2009 | 12:26 PM
SSdan's Avatar
Actually you said you broke a rail.
Old Feb 23, 2009 | 12:28 PM
Psykostevo's Avatar
I never disassemble it there. I just flip it over. It's way easy.........in and out in like 15 minutes.
PhantomSS's Avatar
fail to the max
what he said
Old Feb 23, 2009 | 03:57 PM
Red07Coupe's Avatar
Just for the record, I didn't break the rail. I ment that I had one break on me already. But whatever, last time I help someone on this board, you give a bit of help and another member cuts you up because its not the way he does it.
Old Feb 23, 2009 | 04:04 PM
agreed with phantom. Its easier to do it all in the engine bay.
