How to get stage 2 bolts off NO TOOL??
Old Mar 22, 2008 | 02:21 AM
INFE's Avatar
Im trying to get those pain in the ass stage 2 bolts off and i dont have the tool. I bought new ones from smooth flow pulleys so it does not matter if i mess the old bolts up. Any ideas????
Old Mar 22, 2008 | 02:37 AM
07 SS/SC's Avatar
This might get them loose. I dont think it will though.
In all seriousness, I dont know what to tell you. Alot of guys had to drill the bolts out because they couldnt get them off. I just made sure no lock tite was used on mine.
Old Mar 22, 2008 | 02:46 AM
Pickles's Avatar
If you really don't care just use easy outs like previously mentioned.
Old Mar 22, 2008 | 02:49 AM
KillerBee's Avatar
use a pair of needle nose vise grips is all i can say. Or see if someone by you have the tool you can borrow i am sure someone does
Old Mar 22, 2008 | 02:52 AM
INFE's Avatar
everyone lost the tool lol
Old Mar 22, 2008 | 04:15 AM
MTchevy1's Avatar
Take off the supercharger, clamp the pulley in a vise, take a 3/8" drill bit and drill the heads off the bolts. Then the pulley will come off, and whats left of the bolts in the hub will spin out by hand. I've had to do this on two different cars.
Old Mar 22, 2008 | 05:09 PM
INFE's Avatar
i have been trying vice grips and i just cant get the bolts to turn. I guess i may have to drill them out
Old Mar 22, 2008 | 06:13 PM
chad463's Avatar
off topic a little bit but is it hard to swap the stage 2 pulley with a 2.9 one?
Old Mar 22, 2008 | 06:17 PM
saunders1986's Avatar
i know mine are ****** stuck in there hard............ if u lost the tool, grind a slot in the top of the bolt, and take em off with a flat head screwdriver
Old Mar 22, 2008 | 06:19 PM
tREBs's Avatar
nope. all u need is the ratchet tool, and a 15mm wrench to loosen the tensioner pulley... took me 15 mins
HellbillySS's Avatar
That worked for me
Old Mar 22, 2008 | 07:13 PM
chad463's Avatar
awesome thanks tREBS I am going to order my 2.9 next week.
Old Mar 22, 2008 | 07:34 PM
Netsyphen's Avatar
is there anything I need to know about taking the s/c off? Any fluids that will need to be replaced. What all needs to come off?
My bolt heads are stripped, and I can't get them off with vice grips.
Old Mar 22, 2008 | 07:45 PM
MTchevy1's Avatar
No fluids, unless you have to take off the fuel rail to get at the top passenger side bolt. I just got a 6mm allen socket, and ground off the sides of the socket until it fit in there. Bench grinder works great. You have 2 electrical connectors to take off. The one on the bottom is a little bit of a pain, you have to pull off the little gray clip in it before you can unplug it. Other than that, just a vacuum hose on the boost bypass and two plastic lines. Also need to take off the 2 bolts that hold the coolant fill tube to the supercharger... 10mm wrench.
Old Mar 23, 2008 | 02:10 AM
rukkee's Avatar
Someone has the bit for sale in the classified's
Old Mar 23, 2008 | 02:04 PM
syP's Avatar
syP
am i the only one who left the supercharger on the car??
USE E-Z OUTS
Old Mar 23, 2008 | 02:08 PM
MTchevy1's Avatar
USE E-Z OUTS
It's not always that easy... i broke one trying.
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
