how the hell do i remove the bottom bolt on the intake manifold.
Yea man, unless you have an awesome wrench you gotta take the alternator off. Its 3 bolts, just take it off and move it over a little bit so you have some more room, then just take that elusive bolt out of there.
True, but it took me 1 minute to remove my alt. Once the alt was removed it took 1 minute to unbolt the manifold. Way easier than screwing around trying to get it off with the alt still on.
Yeah, loosen the alt and set it off to the left (front of the motor), then stick a big ratchet with a 15mm on it down there and remove the bolt. Easiest way i've found at least.
OrangeCoba
Sep 25, 2015 06:06 PM
