how the hell do i remove the bottom bolt on the intake manifold.
Old Apr 8, 2010 | 03:04 PM
scotch89's Avatar
Old Apr 8, 2010 | 03:06 PM
rico's Avatar
i got mines off with the alt on and all i dont remmember how tho was too long ago. most people take the alt off to be able to get to it
Old Apr 8, 2010 | 03:18 PM
YzRider452's Avatar
Yea man, unless you have an awesome wrench you gotta take the alternator off. Its 3 bolts, just take it off and move it over a little bit so you have some more room, then just take that elusive bolt out of there.
Old Apr 8, 2010 | 03:20 PM
JapEatr's Avatar
South Central *********
15mm BTW, once you get the alt out the way
Old Apr 8, 2010 | 03:34 PM
scotch89's Avatar
got the alt off. but the intake many being a bish to take off
Old Apr 8, 2010 | 03:44 PM
JapEatr's Avatar
did you get the bolt out?
Old Apr 8, 2010 | 03:53 PM
scotch89's Avatar
yes i did. what im doing is a dual pass endplate. now i just neeed to figure out where to place the bung.
Old Apr 8, 2010 | 04:16 PM
Frew's Avatar
the alt does not, and i repeat, does not need to come off, all you need is a 15mm open wrench and some patience
Old Apr 8, 2010 | 04:19 PM
rnjmur's Avatar
True, but it took me 1 minute to remove my alt. Once the alt was removed it took 1 minute to unbolt the manifold. Way easier than screwing around trying to get it off with the alt still on.
Old Apr 8, 2010 | 04:27 PM
ItalianJoe1's Avatar
Yeah, loosen the alt and set it off to the left (front of the motor), then stick a big ratchet with a 15mm on it down there and remove the bolt. Easiest way i've found at least.
Old Apr 8, 2010 | 05:07 PM
scotch89's Avatar
so i sent the end plate to the fab place now i wait.
Old Apr 8, 2010 | 05:17 PM
Frew's Avatar
why not just get a dual pass of joe here, he makes his own and they are a pretty slick unit I hear
Old Apr 8, 2010 | 09:01 PM
Yep, and I'm pretty reasonable on the price. Also offer core exchanges so you don't have the downtime on your car.
DarrenGC
Dec 24, 2021 01:55 PM
patooyee
Oct 15, 2015 05:11 PM
Tupp
Sep 30, 2015 08:18 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
OrangeCoba
Sep 25, 2015 06:06 PM
