How To Install AEM Wideband?
Old Jan 27, 2008 | 11:03 PM
Kibosh3's Avatar
Hey guys,
After searching the How-To's for the AEM Wideband Gauge, I have found no instructions on how to install it. However, I found one on the LC1... but with no pics...and I'm not even sure if the installations of both of these are comparable... Can someone please help me (or us ) out?
Thanks!
Old Jan 27, 2008 | 11:35 PM
spaz's Avatar
Get a bung welded in the dp Before the cat. Make sure the sensor is tipped up slightly
If you are putting it in the pillar tap the red wire into the pink one and the black one into the black one.
There is a grommet and hole below the clutch pedal on the fire wall. this is where I ran the wiring to the sensor.
Hopes this helps.
Old Jan 27, 2008 | 11:38 PM
ecotecon18s's Avatar
Hopes this helps.
damn, thats it?? not to thread jack, but if I have a tune that turns off the rear 02 and I buy a wideband and install it in the rear 02 bung, then all I would have to do is run the wires and mount the gauge??
Old Jan 28, 2008 | 07:16 AM
Kibosh3's Avatar
Thanks... helpful enough
Old Jan 28, 2008 | 08:28 AM
Rangerondubz's Avatar
Do you still have a cat? If so it wouldnt be a good idea b/c the W/B wouldnt be accurate after the cat
Old Jan 28, 2008 | 08:35 AM
RedEcotecSS's Avatar
^what he said.
Old Jan 28, 2008 | 10:38 AM
Kibosh3's Avatar
where can i get a bung welded for my sensor? can i go to a place like midas?
Old Jan 28, 2008 | 10:41 AM
An exhaust shop did mine, you might have to take the DP out, I didnt but it was a squeeze, the only place I could fit it was the passenger side just before the cat
Old Jan 28, 2008 | 07:59 PM
no kitty here...
Old Jan 28, 2008 | 08:41 PM
rockkrawler628's Avatar
isn't the 02 before the cat anyway?
I could of sworn it was
Old Jan 28, 2008 | 08:45 PM
rob561's Avatar
if you have an 05-06 then your first bung is in the manifold so a cheap route is buy an 07 downpipe because they have a bung before the cat
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
n20saturn
Sep 30, 2015 12:26 AM
yellow dragon
Sep 28, 2015 09:49 PM
