how to install wideband?
Old Jun 21, 2006 | 04:41 PM
Rusty's Avatar
Not exactly sure where I should be posting this, but....
I just bought an AEM UEGO wideband for my car but I have one question about installing it. Where did you bring the wire from the o2 sensor into the cockpit? I don't want to rip apart the entire interior just to find somewhere to bring up the wire if someone else can help me out with this. Any help would be appreciated. Thanks!
Old Jun 22, 2006 | 09:05 AM
Rusty's Avatar
bump....anybody? i know some of you have widebands...where did you run the wire?
Old Jun 22, 2006 | 09:08 AM
CobaltBurst's Avatar
i ran my shift light through the boot behind the brake pedal, it has other wires going through it, i just poked through with a coat hanger. it was easy.
Old Jun 22, 2006 | 09:46 AM
Rusty's Avatar
thank you. but i am not looking for a passage through the firewall. i need to bring up the wire from the rear o2 sensor position behind the cat to the cockpit.
Old Jun 22, 2006 | 09:56 AM
Doc's Avatar
Doc
The O2 sensor for the WB should be in front of the cat IIRC.
Old Jun 22, 2006 | 11:11 AM
just mount the wire somewhere shielded..... not touching anything.... no 2 will be the same...
Old Jun 22, 2006 | 06:11 PM
zinner's Avatar
Moderator Alumni
Best bet is to bring it up into the engine bay and through the firewall, otherwise your drilling a hole somewhere.
Old Jun 22, 2006 | 08:51 PM
BooSSted's Avatar
Zip tie the wire somewhere where it won't get burned from the exhaust. Then run the wire through the firewall and into the car via the hole behind the brake pedal as already stated.
Old Jun 23, 2006 | 08:21 AM
Rusty's Avatar
thanks guys!!!
Old Jun 23, 2006 | 06:29 PM
Rusty's Avatar
finally got it wired up....
i put the wideband o2 sensor where the rear o2 sensor was and zip tied the old o2 sensor to the frame pretty securely. ran the wire up through the engine bay (away from the exhaust) and through the firewall. grounded to the chassis and ran the 12v to the sunroof fuse. i feel much better now. i was apparently running in the 10's at wot!!
Old Jun 23, 2006 | 06:38 PM
Rangerondubz's Avatar
sounds about right
Old Jul 3, 2006 | 05:28 PM
memphisr24's Avatar
Hey Rusty, When I get my wideband, wanna help me install it?
Old Jul 3, 2006 | 05:46 PM
zer0's Avatar
How much slack did you have left from the AEM harness? I had to cut my harness off the car I traded in... you think 6ft of wire is enough to route to the pillar?
Old Jul 3, 2006 | 05:51 PM
CobaltSS313's Avatar
do you think we can gets some pics of the install.
Old Jul 3, 2006 | 07:12 PM
Rusty's Avatar
yea, i'll be down to help. it wasn't too difficult. just took some time. pm me when u get it.
i had plenty of slack left over. it depends on where you want the gauge installed. 6ft might be cutting it a little close, but you could always extend the wires.
i'll post some pics as soon as i finish the gauge pod for it.
Old Jul 4, 2006 | 12:59 PM
sweet
Old Jul 4, 2006 | 09:22 PM
zer0's Avatar
Sorry for being newb but does the removal of the second o2 throw a CEL? May just put in my girls wideband sonner then I thought.
Old Jul 6, 2006 | 10:53 PM
Rusty's Avatar
probably will throw an emissions code. you can always get the bung drilled into your exhaust to keep both o2 sensors in.
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
n20saturn
Sep 30, 2015 12:26 AM
