How much would it Cost?
How much would it cost for me to do put on stage 2 with a 2.9 pulley, the gm stage 2 tune, gm performance exhaust, and header along with a 50 shot wet kit with the purge kit and a tune for the whole car after everything is installed?
And then what do you guys think i should do for traction mods i think id be allset in performance mods but would need some traction to put the power to the ground. I got a girl rite now that told me to make a list of **** i wanted to get done to my car and she would split it with me shed pay it all up front and split it with me and i could pay my half when i got the chance. so how much you guys think it would cost for all of this? and would it be a safe set up and anything else you reccomend?
alrite thats not as bad as i thought... probably wait to do it in the sprign i think thats way too much of a power upgrade to add on the ss/sc with the pirelli tires anyways in the winter. Do you think id needa upgrade the clutch? and how much whp u think id be at?
my bad i forgot about the lnf and didnt even look was just looking for the 2.0 completely forgot bout the turbo balt section sorry
Last edited by streetrcer909; Dec 12, 2007 at 12:32 AM. Reason: Automerged Doublepost
Eh I would saywith parts and labor you would be looking at about 3000+ and do not forget cooling mods if you will be going with a smaller pulley. I would say a C/A Heat exchanger. Also GM STG2 is like 550 through crate...I got min installed for like 175$ at a local dealer.
buy a 2.9" pulley and 42# injectors and stage 2 belt seperately
with cost of installation id say about $2600
STG 2: 550.00
Install: ~150-180
2.9" P: 50.00
Install: about 20-30 min of your time.
GMPP Exhaust: 357.00
Header : 250.00
Install: 100-150 or about an hour to an hour and a half
50 Shot wet kit: ~500.00
Install: ??? I have no Clue ???
Tune: Depends on who....250.00+
So Just That Comes To: 2125.00 +
Traction Mods there are so many you can go with:
- Ingalls Torque Dampner or a Solid Engine Mount
- Poly Engine Mounts
- Lowering Springs
- Strut Bar
- Sway Bar.....Get The Idea?
As far as the other suggestions (Including Other Posts) Here is What I would Say if you have the $:
60# Injectors
2.6" Pulley
GM STG 2 Belt
Full Exhaust W/ a High Flow Cat
Intake (not really nessassary unless you wanna hear more whine)
C/A Heat Exchanger or a Dual Pass End Plate
Meth Set-up
Strut bar
Solid Engine Mount
New Mounts for Tranny Ect
Eibach Sportline Springs
Tune
Total: Prob Around 3500-4000ish
*If you want more information...A Good source if he is still on is Lajavi
** These are some of the Major things you can do
***Dont Really think You would Want the 50 Shot After this Stuff
