How to remove GM security bolts?
Old 05-17-2009, 04:01 PM
IonNinja's Avatar
Kay, I've got a blower with the GM security bolts installed on a 2.79" pulley. I'm trying to swap the pulley out for a 3" but I've never seen a bit this shape in my life.
I'm assuming some type of tool comes with these bolts but I don't have it so...what is it and where can I pick the bit up locally?
Old 05-17-2009, 04:38 PM
mrbelvedere's Avatar
at the auto parts store is where i got mine
Old 05-17-2009, 04:41 PM
06sunburstss's Avatar
if you have the blue gm security bolts you wont find a tool anywhere. I work at an auto parts store and checked everywhere and no one has one. The bit is call a phillips morotrq number 2 bit. I have to contact the phillips screw company and they had to send me one.
Old 05-17-2009, 04:42 PM
rukkee's Avatar
In all the years the stage kit's have been out no one has found a place to get the same exact security bit that comes in the kit's. If you got one at a local parts store please let us know which one . The marking's on the bit is MT-2 and i can only describe it as a twisted star .
Ehhhh what ^ said.
Old 05-17-2009, 04:46 PM
IonNinja's Avatar
SOB I should have known...
that is pretty retarded.
I guess its a long shot but anybody have one they dont need anymore?
Old 05-17-2009, 06:47 PM
06blackSC's Avatar
I have two of them. one is a 3/8" ratchet drive and the other looks like a 3/8" wrench will fit on it. Pay for shipping and the 3/8" one is yours. Let me find them and confirm I have it. PM me tomorrow.
EDIT: Just found it. Its in my hands right now. PM me your shipping info and i'll get you a quote if you are interested.
Old 05-17-2009, 06:52 PM
originaladrian's Avatar
http://www.instructables.com/id/SKYY64QFOVXPHBP/
Old 05-17-2009, 07:03 PM
rukkee's Avatar
It's cool someone found the source of these blue bitches......and the bit that fit's them. Id be surprised to find a bit in a parts store thou.
Old 05-17-2009, 07:28 PM
Maven's Avatar
SnapOn sells Mortorq bits, so do several other tool companies. Its not hard to find, Its just not something youll find at HomeDepot
The Pulleey uses an MT2 I believe, Ive also got MT4 because they use them on the bellhousing of auto trans' now.
Old 05-17-2009, 07:45 PM
IonNinja's Avatar
PM'd
Old 05-17-2009, 07:52 PM
Pyros777's Avatar
It seems this should be it:
http://apexdistributor.com/index.php...d&productId=85
Old 05-17-2009, 08:06 PM
blownredSS's Avatar
I had the bit and it shattered into 4 pieces, and the bolts had no loc tite, best way is to get a 3/8 drill bit and drill the head of the bolt, it will fall right off. Pm me if you have any questions.
Old 05-17-2009, 08:30 PM
ItalianJoe1's Avatar
A good sharp chisel works well too.
Old 05-20-2009, 02:42 AM
IonNinja's Avatar
yeah I don't know if I wanna destroy them...I just want to get them off lol
then I can sell them with the 2.79 pulley
Old 05-20-2009, 07:33 AM
SS_Supercharged's Avatar
The "security bolt" is not a security bolt. It is a Mortorq bolt desinged by the Phillips Screw Company. The Mortorq bolt was designed for the aircraft industry to be able to design a small headed bolt that can have a lot of torque applied to instal and to remove with out damaging the fastener. The bolt is a Mortorq size #2 or MT-2. You can read more about the Mortorq design here:
http://www.phillips-screw.com/aero_mortorq.htm
Two MT-2 bits were provided with every LSJ stage kit sold. If you don't have an MT-2 bit you can purchase a bit here:
Old 05-20-2009, 11:23 AM
KillinKrullin's Avatar
use a power drill and chuk the drill directly on the bolt. thats how you also get out things you strip..
have fun
Old 05-20-2009, 12:04 PM
Coop's Avatar
Nice to know.
Old 11-01-2009, 11:20 AM
cobalt123's Avatar
i bought one of a member here
Old 11-01-2009, 11:25 AM
c0ld29's Avatar
I got mine at autozone, it came in a "Security Bit Kit" or "Utility Bit Kit" I forgot what they called it but it came with probably 60 bits or so. It was in a small blue plastic box with latches on the tool aisle. I believe it is made by Greatneck and has a yellow jacket over it. Thats about as specific as I can be lol.
The only problem with mine is after I got it and tried to undo it I realized they put F'n loctite..
DarrenGC
12-24-2021 01:55 PM
hacadacalopolis
10-28-2015 06:09 PM
SSLOW06
10-01-2015 07:21 PM
Tupp
09-30-2015 08:18 PM
CobaltSS 16
09-29-2015 01:53 PM
Quick Reply: How to remove GM security bolts?
