HP Tuners Limit Boost In Second?
Old Jan 29, 2007 | 09:52 AM
Gonzo2007's Avatar
I have an 07 ss/sc and am going to go stage 2 with full exhaust in the spring. I was a little concerned about traction considering it is already a liuttle sketchy. Can you use HP to limit boost in any gear?
Old Jan 29, 2007 | 09:55 AM
Witt's Avatar
There is a parameter to limit boost in second but it affects boost in 3rd 4th and 5th as well, even though HPT says it shouldn't. The parameter to change boost in 1st gear only affects 1st however.
Old Jan 29, 2007 | 09:58 AM
Gonzo2007's Avatar
So that means if you limit 2nd to 13 pounds or so your other gears will be at the same?
Old Jan 29, 2007 | 10:02 AM
Witt's Avatar
I did it on an '06 which limits boost by percentage. I set the value to 50% and it went right to 100kpa max in second (0psi) and did the same for 3rd 4th and 5th. If you read the tooltip description for the value you change, it says it will only affect second gear, but its not correct on our PCMs as it affects others as well.
Old Jan 29, 2007 | 10:04 AM
KillerNutz's Avatar
On my 06 I just have boost limited in 1st, and that pretty much solves my traction issues. I wouldnt mess with 2nd-5th you should be fine with full boost.
Old Jan 29, 2007 | 10:05 AM
NoRemorse's Avatar
Better way to do it in an 06+ is to use Torque Management. Limiting it by % will vary depending on atmospheric conditions. If you use TQ management it will be consistent every time, and also varies boost and timing to reach desired effects.
Old Jan 29, 2007 | 10:09 AM
Witt's Avatar
Now thats something I haven't tried. As NoRemorse said, there is a desired torque value for each gear. That may work for limiting boost in second gear and second gear only. I know for a fact though that the Max Boost (2nd gear) value does not work correctly.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
OPCrer
Sep 27, 2015 08:11 PM
