HPT's take on E67 ECU for LSJ
If I knew how he got the Bin file and an adapter to the E67 ecm, so I don't have to rewire if it doesn't work to get it back, I would do this. I, more or less, think I have the idea of what he did. It appears he never got it running right because he disappeared.... Or just wanted to sell his findings.
I was just literally talking to someone about doing the same thing haha. Swapping back and forth if it didn't work would be a pain in the ****
why not circumvent all of this crap and stick a damn standalone and a cable driven tb on it and call it a day.
The last lsj ecm up date from hpt was the dynamic airflow table adder. nothing since then. that was 2008.
keeping the gauges is the key and unless some makes a plug and play I doubt anyone would bite on it
A parallel ecu install allows the stock ECU to see all the sensors and think it is working normally because everything is within parameters of the stock ECU. An aftermarket ECU will ACTUALLY control the engine and share some sensors (some that are resistance based sensors, such as engine coolant sensor, can't be shared).
Why I say in theory is sometimes the stock ECU can find out that its outputs have been shut off (stock ECU demand one thing but another thing happens) and throws a code. You disable the code and problem solved. There might be little glitchy things that will happen, though.
This would NOT be a piggy back system because you are NOT sharing any engine responsibility between the 2. Only the aftermarket ECU
I have wondered about doing this and have researched it a bit. It is VERY involved and being the first would be pretty tough (or at least not getting help from others whom have done it). It has been done with racing Ecotecs but none of them stick around.
In the GM build book for Ecotecs, doesn't it talk about a F.A.S.T. X.F.I. system?
I got the same response from the guys at HPT.
Looks like someone here may have had luck with TunerPro?
2007 TunerPro Bin Files
so answer that smart ass
The aem standalone is reasonably priced. I don't think retaining gauge operation would be that difficult.
Heck even an ms3 is a decent and affordable way to go of you can do basic wiring and follow instructions.
The reason is he doesn't has been messaged but won't answer. We also posted on his thread asking with no response.
it would be extremely difficult. the aem probably wont work with gm's secret squirrel can bus
