I/C Pump Working?
I/C Pump Working?
I turned my ignition on and checked to see if I could hear the pump running and nothing, and i also started the car and checked but its too hard to tell. I also noticed for the last little bit my car doesn't seem to pull as hard. Can anyone post a picture where ya open the cap to see if theres bubbles or anything flowing? Thanks.
07 Cobalt SS/SC
GM Stage 2
07 Cobalt SS/SC
GM Stage 2
Pump has nothing to do with boost. If you have an interceptor you will notice your IAT2 is higher than it should be, and doesn't recover quickly.
The easiest way to tell aside from HPT is to start the car and stick a straw into the filler neck. See if it gets pushed around.
filler neck is in front of the supercharger intake side
take off the cap and start the car, if coolant is not flowing then take a hammer and whack the plastic side of the pump underneath the car until it begins to run
just be sure to not damage the pump
just had to whack mine today with a hammer. fixed it up good as new. I noticed earlier today that my IAT2's were a bit high. opened up the filler neck and sure enough, no flow, no bubbles, nothing. crawled underneath whacked a few times with a hammer and wouldn't you know. It started pumping and flowing again. IAT2's right back to where they should be.
If my car wasn't so low to the ground I would get underneath it and whack it with a hammer, but nooo my car has to be super low lol. I think mines getting replaced under warranty today, not sure though. My iat2's have been through the roof, can't wait to get it working again.
So I opened the cap and started the car and can`t see anything flowing or anything at all for that matter ... I can see a little bit to the side thats it but nothing moving. Where at exactly to ya hit it to try to get it working? I can see the pump but its too hard to get at it do ya hit something from up top?
I replaced mine at about 35000 miles and the dealer told me it didnt matter because the extended warranty would cover it. So also not sure about the 60k warranty.
Last edited by SCcobaltSS; Apr 14, 2009 at 04:19 PM. Reason: Automerged Doublepost
