I know this has been asked but i could find it..
about how much should it cost to just have the reflash done on the stage one kit and can i drive to the dealership to have it tuned with the 42 lb injectors in
i really dont care i just want to know how much it will cost and i dont know if it will make a differences but i am not going to the dealer i usually go to they are to far
if you have a competent dealership when it comes to the stages, then just a reflash should only charge you like an hour at the most worth of labour, like 60-80.
call your dealership, thats the easiest way to find out how much it will cost. if they don't know what stage 1 or 2 is, then either inform them exactly what you want over the phone, or go somewhere else. If you have a dealer that is affiliated w/ GMPP goto that.
ok the s2 tune is the same as s1 i dont have s1 yet that is y i want the tune and if it is just a reflash it should only take at must 15 min but i would think i would get charger for like 30 min because they charge by the half hour
anyone know what 30 min of work at a dealership cost and if i can drive my car like 15 miles with the injectors in and no tune
In order to get the flash from a dealer, you need a STAGE 1 KIT ($385 @ CED). They need the unique number from the kit in order to get the flash installed on your car. If you already have the kit, and it is installed (injectors only if it is stage 1), then the dealer will probably charge up to 1 hour of shop time.
If you just want the flash as you already have injectors, but no Stage Kit per se:
Then it makes no sense financially (warranty aside) to get another stage 1 kit just for the flash. It would be better if you could get a stage 1 (or 2 - same dif) flash from someone with HPT. This could possibly be free (if they have registered your year) or cost a bit to register your car.
sounds very reasonable.
Plus the $300 to $400 for the kit itself.
agentirons
Oct 16, 2015 02:11 AM
