I need an answer now! please read
Old May 29, 2008 | 04:13 PM
blk ss/sc 1's Avatar
alright im pissed ive been outside for 2 hours.. im puttin my new exhaust and downpipe on ....the exhasut isnt a probelm but i cannot get the damn stock downpipe off.. None of the bolts or anything will come loose.. has anyone had a probelm.. how the hell did you get it off?
UPDATE WOO FINALLY GOT DONE ABOUT AN HOUR AGO taking off the stock downpipe was the biggest PITA i ever had to do.. but wow i cant believe how good this system sounds.. its the magnaflow cat-back with a zzp catted DP and stock manifold.. i'll get a vid tmrw.. it's too dark out right now... but for anyone getting an exhaust i highly recommend this one!
Old May 29, 2008 | 04:15 PM
YellowLT's Avatar
Rust Penetrator and a breaker bar
Old May 29, 2008 | 04:17 PM
nutsandboldts05's Avatar
Cutting torches
Old May 29, 2008 | 04:18 PM
gotboost21's Avatar
PB blaster and lots of heat
Old May 29, 2008 | 04:19 PM
Eagle_f90's Avatar
My bolts where rusted in on mine I just soaked them in wd-40 and used a lot of cuss words when trying to get it off. Like an hour later I got it off.
Old May 29, 2008 | 04:20 PM
Jumpin Fool's Avatar
Feasable, and makes sense at least.
But this one...
Originally Posted by nutsandboldts05
Cutting torches
You, fellah, are fired.
Old May 29, 2008 | 04:37 PM
ChevyRockstar's Avatar
elbow grease
and Cheater bar FTW!
Old May 29, 2008 | 04:39 PM
SuperchargedSS's Avatar
Deep Creep, and a breaker bar. You could possibly hit it with some heat to expand the holes but be very careful. If not drive it to a garage with just the down pipe on, and get ready for some jokes to be tossed youre way !!!!
Old May 29, 2008 | 04:40 PM
Forced>Induction's Avatar
Dude if you dont need the damn stock downpipe just sawzall that biotch right off there. JK what you should really do is spray with the PB blaster let it sit, then after it has penetrated, heat those suckers up with a small torch and they should crank right off!!!
Old May 29, 2008 | 04:47 PM
stonny9's Avatar
wd-40 to the bolts and let them sit for 10 mins. then take a breaker bar to them. If that fails then cut the bolts off and get new ones at the hardware store. I ha one new bolt on the header/dp flange as a stock one stripped off the threads on removal.
Old May 29, 2008 | 05:12 PM
alright.. update... after an hour and a half.. pb blasted the **** out of it and used A LOT of cuss words.. and the result was breaking 2 bolts out of 4 and 1 nut.. but i got the 02 sensor out with no prob.. my buddy is bringin his drill up to dirll out the bolts and we're goin to put new ones in so hopefully we have no more problems.
Old May 29, 2008 | 05:15 PM
Supercharged06's Avatar
i used an air wrench, that worked pretty good
invisible's Avatar
You need to use some of this.
Has worked every time for me.
ssweeet's Avatar
Dude. I went at this all day when I was taking off my stock downpipe. From ******* 10am to 7pm. I even rode around town with my downpipe unbolted from the resonator to get the things I needed. You just have to keep trying. YES it is VERY VERY VERY frustrating, but then will eventually come loose.
RaginChopsuey
Oct 27, 2015 01:27 PM
Tupp
Sep 30, 2015 08:18 PM
dennis69
Sep 28, 2015 02:16 PM
DocSvensk
Sep 27, 2015 02:24 PM
jmelton327
Sep 26, 2015 10:04 PM
