I need help with my engine replacement
Old Feb 7, 2025 | 02:54 PM
Isaac's Avatar
I put in a new engine with no knowledge of what I was doing, I am in the final stages but have no clutch operation, I think it could be do to this hose, anybody know what goes here what it’s called and what it does? Thanks!
Old Feb 7, 2025 | 03:04 PM
KMO43's Avatar
There is a hose that connects the brake master cylinder to the clutch master cylinder. This hose needs to face down towards the clutch master cylinder to not catch an air bubble. I usually turn the clutch master cylinder clockwise 90° to help with this. You are trying to help the fluid gravity bleed into you clutch master. You can loosen the bleeder on the slave cyl and it should gravity bleed over time if you have no high spots. Good luck
Old Feb 7, 2025 | 05:38 PM
Isaac's Avatar
Thank you so much! Hopefully it works!
G_Pelly
Dec 19, 2024 10:33 AM
coyn11
Jan 12, 2013 02:01 PM
joe0016
Apr 24, 2010 04:20 PM
hinow41
Jun 4, 2009 06:46 PM
blu3_v1p3r
Feb 17, 2009 02:15 PM
