i need a how to:)
Old Oct 7, 2011 | 06:31 PM
Bl@ckC0balt's Avatar
i need a how to:)
anyone know of a how to on replacing my starter
all the help is greatly appreciated
Old Oct 7, 2011 | 08:39 PM
ben_gary's Avatar
1.turn the ignition key to off, then disconnect the cable fromt he negative battery.
2.raise front of vehicle and place on jackstands. on 2.0 lsj, drain intercooler coolant and remove ic pump.
3.disconnect battery cable (larger cable) and starter control cable (smaller cable) from starter motor solenoid termials
4.remove the starter mounting bolts and remove starter. on 2007 models, may have to remove secondary air injection pump (disconnect electrical connectors, hoses and 2 mounting bolts) to allow room for starter removal.
5.install is reverse of removal. tighten starter bolts to torque spec-30ft-lbs for all and 2006+ lsj-37ft-lbs.
6.when battery has been disconnected, the PCM must relearn-
a.-start engine and allow to warm up to normal operating temp.
b.-drive at part throttle until normal performance returns.
c.-park and apply parking brake with engine running.
d.-on manual trans, put in nentral. on auto trans, put in drive.
e.-allow engine to idle for about two minutes, or until idle stabilizes.
Old Oct 8, 2011 | 11:37 AM
Leafydialupking's Avatar
Dont have to drain the intercooler, you can just unbolt the pump and move it out of the way.
NJHK
Forced Induction
40
Feb 21, 2019 12:50 PM
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
CobaltCoupeCrazy
Feb 18, 2007 06:41 PM
CTCOBALTSSS
Oct 20, 2006 08:57 AM
