I want to swap my Tranny
Old Apr 15, 2012 | 01:58 PM
imjuliooo89's Avatar
Exclamation I want to swap my Tranny
I've been told that the TC's have better tranny's and can be put on the SC's. Is there any truth to this? If so, anyone know of any web sites that sell the tranny's? Also, if i do go ahead and buy a new tranny, would it be wise to buy one with a Limited Slip Differential? All help is appreciated.
I think its good for me to note that i am not very car savvy, but i love to learn & have only been able to start learning because i bought this car myself and never had a car to work on and learn until i bought this one.
Old Apr 15, 2012 | 02:13 PM
G11's Avatar
G11
It has a stronger case and yes a LSD would be a good thing...another thing that is different is the final drive gear. Go to car part.com and you can find some used ones possibly
Old Apr 15, 2012 | 02:27 PM
sounds good. Also, are the gear ratios longer on the TC's tranny?
Old Apr 15, 2012 | 02:34 PM
Sharkey's Avatar
the final drive ratio is the only difference, the ss/sc is 4.05, the ss/tc is 3.81. that means longer in each gear and lower freeway rpm
Old Apr 15, 2012 | 02:38 PM
oh okay, so the SC has the longer gears then...or the TC? im so lost.. haha
Old Apr 15, 2012 | 03:11 PM
okay okay, makes sense. thank you for the break down.
Old Apr 15, 2012 | 03:21 PM
Rubbermaid_LSJ's Avatar
Try to get the "Gear length" out of your head. It will only confuse you, until you understand the concept of the ratios. "Gear length" has an inverse relationship to the ratio number, and is a relative term which can really only be used in comparison between two cars.
The following is assuming that the cars are Identical except the transmission's final drive ratio. (note that the transmission has a few gear raitos, this is assuming they are all identical other than the FINAL DRIVE RATIO)
1. The 4.05 will accelerate faster (assuming 100% traction) than the 3.81.
2. The 3.81 will have a higher top speed. This is true as far as the top overall speed and the top speed in a specific gear. Say the 4.05 hits 20mph top speed at redline in 1st. The 3.81 will redline traveling faster than 20mph... (This is where the term gear length comes from, so the SC has a "shorter gear")
3. The 3.81 will have better MPG "Cruising" and will be at a lower engine RPM at any given speed than the 4.05 in an identical gear. (Similar to #2.)
EDIT:
Haha i thought i was confusing, so i deleted and re-submitted a better breakdown... Happy to help i guess :p
Last edited by Rubbermaid_LSJ; Apr 15, 2012 at 03:21 PM. Reason: Automerged Doublepost
Old Apr 15, 2012 | 08:33 PM
mrbelvedere's Avatar
gm setup the transmission perfectly for the lsj so why change it
Old Apr 16, 2012 | 12:36 AM
Sharkey's Avatar
not always true. it is commonly thought that a numerically lower high gear will give better economy, really thats an old line of thinking coming from the era before overdrive transmissions. yes, in your old car with a 4 speed stick, a 3.73 ratio will get worse fuel economy than 3.55s. its all about keeping the car in its best efficiency range. ever notice that some cars will get better economy at 75mph than at 65 or 70? thats just because the engine is in its best efficiency range for cruising. its not always the lowest rpm possible.
ThoR294
Oct 4, 2015 08:44 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
