IDC's???
It is said to not pass 85% IDC. Some go more than that, but my opinion is that if you continue to drive it like that you're going to hear a large boom followed by oil coming out the back, if you know what I mean.
idc stands for injector duty cycle, and its in percent. 0% would be the injectors closed all the time, 100% would be fully open all the time. running the injectors past 85% reduces the life of them. now you cant go past 100%, the injector cant be on more than all the time. anything past 100% and the motor will lean out. in general on a stage 2 tune its very rich and when it leans out with the injectors at 100% its still somewhat safe depending on what pulley you have
I went to this website and had the converged it over and it said my idc where high. And was wantng to do with a 2.9 but don't wanna be to lean knowing I won't have any fuel at high rpms
An injector in an engine turns on and off very quickly to control the amount of fuel delivered. The amount of time an injector is turned on and delivering fuel is known as the duty cycle. This is measured as a percent, so 50% duty cycle indicates that the injector is held open and held closed for an equal amount of time. When the engine needs more fuel, the time that the injector stays on (its duty cycle) increases so that more fuel can flow into the engine. If an injector stays on all the time, it is said to be static (wide open, or 100% duty cycle). Injectors should not go static in a running engine. If an injector is static in a running engine (open 100% of the time), that injector is no longer able to control fuel delivery. This could be an indication that the injector is too small for the needs of the engine. Injector duty cycle should usually not exceed 80% in a running engine at any time.
I would look into getting some 60lbs injectors. and getting retuned, 60 would be a good investment with your current set up. in my opinion, cooling mods would be nice to, you would benifit alot from some
i dont know what the scan gauge can all read, its been a while since i looked into scan gauges,
I would strongly advise you not to put 60lbs in unless your able to tune or get the car tuned right after installing them, for you could run way too rich and wash your piston seals out, I've seen it happen locally, if you going to do 60's make sure you can tune or have a tuner avaliable.
Last edited by OneCOLDBIZL272; Sep 16, 2009 at 08:36 PM. Reason: Automerged Doublepost
No I'm asking. It can read pulse width. What I'm asking is instead my scan gauge might be reading the stock injectors since it says my pw is 19.4 at redline. Which in turns the idc is like 113%. And what u said makes sense about not being able to be on more than 100 so where is the prob coming n at?
So I need at tune whch I can't get hmm I guess bolts on till I can get 60s
Last edited by 07touringcoupe; Sep 16, 2009 at 08:41 PM. Reason: Automerged Doublepost
firepinch
Jun 17, 2008 07:22 PM
