An Idea: TVS with ZZP's 2.3L Stroker
Old Sep 28, 2009 | 08:54 AM
tryit's Avatar
The only issue I see is that with the added cubes it would loose the ability to turn serious rpm's. This is why alot of evo guys take a 2.4 and destroke it to a 2 litre. Id say just build your motor with stock cubic inch port the head get cams and run a GT30R or a GT35R depending on how much horsepower youd like to make. Remeber ith any forced induction setup its all about moving mass amounts of air so a high boosted car with stock heads could be loosing a signifcant amount of horsepower.
Old Sep 28, 2009 | 09:04 AM
sport08's Avatar
Originally Posted by STS2/SS
So then what should we be looking at? maby 9000 rpms? I can shim springs to get more seat pressure. I think I'm just trying my damndist to get freakta's car to break 400whp with a supercharger! I like the feel of the TVS. I've been in a turbo car and it feels like every other turbo car, fun for like 3000 rpms.
I need as many rpms as I can get. I will restructor his head intake runners to accomadate this airflow. The most work I spend on the LSJ is in the exhaust side! I'm going to try my hardest to squeeze every last bit out of this head! I just wanted to try something diffrent. But your right there is no valve spring yet that can handle these RPM'S!
I would recommend if your ganna use 60's to direct inject methonol! You will be able to better tune you engine with 60's.
With the 2.3 strocker I would assume 280-310 with your setup on pump gas...
Due head work, and at the minimum adjustable cam gears or get Zooomers cams his power band on the dyno sheet looked rediculous!
i think he will make much higher numbers then that... alot of people on this site ex. rodimus_prime made what ur guessing with the 2.0L
Originally Posted by rodimus_prime
I think 330 is conservative with a TVS, I hit 298whp with massive spark blowout above 5500 and a unfinished tune. Keep in mind this is without the benefit of added displacement, ported head, upped compression, or upped rev ability. I think 350-400 is a more realistic expectation with a motor built.
he will make much more power then 280-310 on the 2.3L stroker
Old Sep 28, 2009 | 09:39 AM
Doc's Avatar
Doc
I believe the race prepped GM motors (2.2 turbo) spin to 9500.
Remember, GM destroked the 2.2 to accomodate more RPM's. I remember seeing the test results for the 2.2 while they increased horsepower from 200 to 1000+. I don't remember if the max was 1045 or 1400 though......
Old Sep 28, 2009 | 09:51 AM
freakta's Avatar
when did my car get sucked intoall this talk of rpm and everythibg else. hahaha, its gonna be a fun trip, solid lifters would help the top end rev out a bit.
and for everyone say o build a honda, build a rotory, he has. he has built alot of stuff and we will succeed with this car too
Old Sep 28, 2009 | 05:46 PM
drew1991sf's Avatar
does the stroker kit come with pistons, rings, rods, etc? or wat does it come with.
Old Sep 28, 2009 | 07:13 PM
HunterKiller89's Avatar
well, it would have to come with rods...but pistons and rings might be stock. Wait till it's released...they might not even know yet.
Old Sep 28, 2009 | 07:15 PM
drew1991sf's Avatar
i dont see why they are so secretive all its gonna do is make the ppl who are interested just go a different route becuz they dont want to wait for zzp to release it
Old Sep 28, 2009 | 07:34 PM
STS2/SS's Avatar
I would go twin charge with the 2.3. I would also flow the head just enougf to make the turbo happy! Then the sky's the limit...
Old Sep 28, 2009 | 08:36 PM
i dont think its a secret...i think they just havent finished a product that will be sold to the public yet... how can you release specs on something that hasnt been made yet?
Old Sep 28, 2009 | 08:44 PM
drew1991sf's Avatar
well they used it in one of their cars so they should know the specs lol
Old Sep 28, 2009 | 09:11 PM
  #36
their prototype likely wont be the final product though
Old Sep 28, 2009 | 09:21 PM
  #37
drew1991sf's Avatar
but close enough to let us know anything about it
Old Sep 28, 2009 | 10:18 PM
  #38
well, its an 86mm bore and a 3.5" stroke...sooo theres some about it. The only missing info is what parts are used
Old Sep 29, 2009 | 05:07 PM
  #39
tryit's Avatar
Originally Posted by Area47
ok, got me there!
the shop cars spin to 10,500-11k. built b-series honda's with off the shelf parts
::shrugs::
spinning an engine to 12-13k is all fine and dandy. why? no idea. no point. you want that level of rpm. go build a rotary engine.
Agreed its pointless to have useless rpms. It would mearly be just a bragging right and nothing more.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
