Ideler Pulley
Old Aug 3, 2008 | 09:23 PM
chad463's Avatar
Ideler Pulley
Has anybody changed the ideler pulley before? How hard is it to change?
Old Aug 3, 2008 | 10:04 PM
Doc's Avatar
Doc
The pulley itself, very simple. It uses a torx bit, think 45 or so. Watch your knuckles though...if it slips off, your knuckles are toast.
Using the idler pulley bolt is actually another way to relieve tension on the belt. I've had to use it on more than one install.
Old Aug 3, 2008 | 10:09 PM
chad463's Avatar
awesome, do you know how much that pulley will run me? Where would I be able to buy this at?
Old Aug 3, 2008 | 10:11 PM
Doc's Avatar
Doc
the stock idler pulley..??
Old Aug 3, 2008 | 10:13 PM
chad463's Avatar
I am putting a 2.8 and I seen the Rebel stage 1 kit has a larger one. So I was thinking a larger one if its not needed I would put a stock one.
Old Aug 3, 2008 | 10:15 PM
Doc's Avatar
Doc
here....if you want a 76mm idler pulley, don't go to one of the various forum vendors....they are charging way too much.
The maker is Gates Corporation and the part number is 38009. Just search pulley 38009 on google and you'll see it cost $12 from rockauto.com
Its a 76mm drivealignŽ groove pulley part number 38009
Old Aug 3, 2008 | 10:25 PM
chad463's Avatar
so thats the pulley that goes on top of the tensioner and the stock size? It has the grooves and everything in it? Thanks for all the help
Old Aug 3, 2008 | 10:28 PM
Doc's Avatar
Doc
thats a bigger pulley, perfect fit when using a 2.8 and smaller belt.
Old Aug 3, 2008 | 10:30 PM
chad463's Avatar
there is no modification needed to install this? Do you know where I could order the stock size as well?
Old Aug 3, 2008 | 10:44 PM
Doc's Avatar
Doc
No modification needed, well..a smaller belt (stage 2 belt #12597993).
You can get it from a GM dealer...give me a few days and I can get a part number. Or you can go and request the part number yourself.
Old Aug 3, 2008 | 10:58 PM
chad463's Avatar
alright thanks a lot. I was just thinking that with the stage 2 belt and the bigger idler pulley that it would be too tight. I will go to the dealership tomorrow and see if they can get me a part number.
Old Aug 3, 2008 | 11:00 PM
Doc's Avatar
Doc
it will be tight, but perfect
Old Aug 6, 2008 | 08:30 PM
chad463's Avatar
Whats the size of the stock one? Does anybody know? I need to order one of these as soon as possible.
bump somone must know this. I dont want to pay 400 bucks for the whole setup.
Old Aug 6, 2008 | 08:34 PM
Josh@ottp's Avatar
chad I have a used stock one with around 5k on it. Pay the shipping and its yours.
Old Aug 6, 2008 | 08:41 PM
chad463's Avatar
sounds good, how much is the shipping?
Old Jan 20, 2011 | 05:24 PM
insylem's Avatar
Question
I want to know too please!
I don't need the Pulley,
But I baught my car used, with a 2.85" SC Pulley, and I know
the belt won't last forever. I need to know if I have an oversized pulley
or an undersized belt.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
