Just ported my Throttle body.
Old Jan 18, 2011 | 10:52 PM
ecot3c inside's Avatar
was bored today and I decided to do this really quick. fairly easy, I didn't even have a dremel, I used my cordless drill with dremel bits. The picture is before I polished it and smoothing it out (the white stuff you see is where I marked the throttle plate at rest), the plate I knifed the edges top and bottom and polished both sides making it smooth. cost me $10 and an hour.
my butt dyno says a 3hp increase in better throttle response, supercharger whines a little louder as well.
Old Jan 19, 2011 | 12:01 AM
Stone629's Avatar
Not bad at all! Should hit it with some emery cloth to smooth out those scratches a bit.
Old Jan 19, 2011 | 12:03 AM
redcobalt07's Avatar
yeah now you need the polish aspect
Old Jan 19, 2011 | 12:14 AM
goeckeritz123's Avatar
How did you know how much to take off
Old Jan 19, 2011 | 12:15 AM
that picture was taken just before I smoothed it out, it defiantly doesn't look like that. Just a size comparison, You can see I got that lip out in the middle.
Old Jan 19, 2011 | 12:20 AM
I didn't, just took off what I thought was necessary and made it as even as I can without taking off too much (or not at all) where the plate sits. Turned out real well.
Old Jan 19, 2011 | 12:34 AM
Erick161's Avatar
Well, my car showed 5WHP with a slightly enlarged throttle body...so i dont deny a gain...
Old Jan 19, 2011 | 12:45 AM
Did you have to tune after. And how do you Polish it to smooth it out jw
Old Jan 19, 2011 | 12:55 AM
Erick161's Avatar
I personally didnt have a tune, just a raw gain of 5whp, im not sure about the OP
Old Jan 19, 2011 | 01:01 AM
Reaper06's Avatar
does iy idle ok for with a larger gap around th throttle blade at idel to me would raise the rpms a little yes no? either way A+ for doing it yourself and not blowing a 100+ bucks
Old Jan 19, 2011 | 01:54 AM
ya no tune, my afr was pretty much the same o2 should compensate for the small air increase. not sure what happens when you take from around the plate because our throttle is open 16% at idle anyway, just to be safe I just smoothed around it.
Old Jan 19, 2011 | 02:37 AM
So pretty much mark where the plate sits and make sure not to touch their
Old Jan 19, 2011 | 10:58 AM
correct, you can defiantly smooth it out around where the plate sits a little with what looks like; I used a wire polish sanding wheel of some sort (idk what it's called, but it's a little softer), but everything else that isn't touching is fair game..... maybe I should have took more pics and did a write up for you guys, sorry.
Old Jan 19, 2011 | 11:06 AM
hawlyns711's Avatar
nice that looks like a similar port that my saturn motorsports TB has!
Old Jan 19, 2011 | 11:50 AM
SCcobaltSS's Avatar
I still disagree with this number like I have said in the past. My sits at about 7-9%..
Old Jan 19, 2011 | 11:59 AM
07BoostedG5's Avatar
^ mine sits at 12%
Old Jan 19, 2011 | 12:14 PM
according to my interceptor at cold start. That's just where it's at.
Old Jan 19, 2011 | 01:05 PM
SCcobaltSS's Avatar
check it on HPT my guess its different.
Old Jan 19, 2011 | 07:37 PM
xxxxsh4d0wxxxx's Avatar
So what you're saying is take off my TB and come over and you'll do mine next?!
How's Friday sound?
Old Jan 19, 2011 | 07:48 PM
383_Stroker's Avatar
3hp according to the butt dyno? Yours must be calibrated better than mine..
Old Jan 19, 2011 | 11:34 PM
How's Friday sound?
sounds like crap! lol, i have school
eh, i think its pretty accurate...
Last edited by ecot3c inside; Jan 19, 2011 at 11:34 PM. Reason: Automerged Doublepost
Old Jan 19, 2011 | 11:44 PM
jamies06ss/sc's Avatar
wat did you have to do to run the 3 in DP on ur GMPP exhaust?? anything special?
did you have to do anything to ur GMPP exhaust to get that 3 in DP to work?
Last edited by jamies06ss/sc; Jan 19, 2011 at 11:44 PM. Reason: Automerged Doublepost
Old Jan 20, 2011 | 12:51 AM
No it has a 2.5 bolt in
Old Jan 20, 2011 | 07:49 PM
When then?!
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
