Idle problem CURE!!!!!!!! Finally!!
Old Mar 9, 2013 | 01:03 PM
  #451
Bad-A-SS's Avatar
Alrighty guys heres the video... You can see where it hangs when I press in the clutch and knock it out of gear
Old Mar 9, 2013 | 01:42 PM
  #452
Gelladuga69's Avatar
Yup, mine does the exact same thing until I come to a dead stop. Then it idles at 750.
Old Mar 9, 2013 | 01:47 PM
  #453
Bad-A-SS's Avatar
Yeah its never did this before, until I cleaned the tb
Old Mar 11, 2013 | 10:48 PM
  #454
SalvageBaltSS's Avatar
i just watched the vid, ya mine does the same thing, You didnt bend anything! lol my bad.
Old Mar 11, 2013 | 11:12 PM
  #455
Bad-A-SS's Avatar
Oh ok so I just need to get tuned and you think it might fix it? Because it never has done it before
Old Mar 20, 2013 | 02:10 PM
  #456
i think even with a tune ill do the same thing? and arent you going turbo? i think i bought that downpipe off ya.
Old Mar 20, 2013 | 02:54 PM
  #457
turbosmart4's Avatar
**** happens to me too and pisses me off cuz I have ttr mounts and when idle drops its chaos
Old Mar 20, 2013 | 06:11 PM
  #458
Bad-A-SS's Avatar
Yes sir PT5558 by precision
Old Mar 21, 2013 | 11:53 AM
  #459
chris88z24's Avatar
If you unplugged the battery it'll idle like that. Otherwise you prob have a vacuum leak or broke something related to the drive by wire system...
Old Mar 23, 2013 | 03:18 PM
  #460
t1ndell's Avatar
Can't seem to remove that sensor. Help?
Old Jul 25, 2013 | 03:58 PM
  #461
EvilOni22's Avatar
low idle to idle spike.
Ok, I have read most the thread, cleaned throttle body and what not. Good strong battery and alternator, with clean connections. Have 06 SS/SC stage 3 by GM standards. Slightly smaller pulley on SC then recommended. Only 36k miles. When the weather is warm it runs better but still can happen. When weather is cold, its almost constant. Idle runs really low then spikes up to round 1500 then bounces its way back to low and spikes again. sometime stalls. Plugs checked and gauged, run premium fuel, just dont know what to do now, any ideas at what is causing this or to try next? I do have a transmission fluid leak that i am aware of, but don't see how this could have anything to do with it. Thanks for feedback. Oh! runs smooth and steady with throttle on or while just coasting at low rpms just does this while idling in neutral or coasting at any speed in neutral. I have noticed that the faster I coast, the higher the rpm can spike on the bounce and the more frequent it spikes. if that helps narrow any ideas down. Thanks again sorry for the book.
Old Jul 25, 2013 | 04:00 PM
  #462
EvilOni22's Avatar
Sorry runs smooth while coasting at low rpms in any gear ^ but idle lowers and spikes while coasting in neutral if that was not clear.
Old Jul 25, 2013 | 05:20 PM
  #463
speedbugy996's Avatar
I would suggest O2 sensors, my idle issues recently returned even with brand new injectors and other sensors. Only ones not replaced were O2 sensors, the primary was replaced last fall, so we replaced the secondary and issue ceased.
Old Jul 27, 2013 | 06:21 PM
  #464
EvilOni22's Avatar
thanks
Thank you for the suggestion. Ill look into that.
Old Jul 28, 2013 | 04:36 PM
  #465
kellydood's Avatar
I got my '06 SS/SC a few months ago with 80k on it. It had a crappy, surgy idle, and even stalled a few times. I cleaned the TB as suggested, and voila!, cured. Thank you so much for taking the time to put this together.
Old Jul 29, 2013 | 08:49 PM
  #466
EvilOni22's Avatar
I have an update on mine as well. Someone else suggested to me elsewhere in the forums about secondary o2 sensors. I have not done this yet but will soon and let every know if that helped. Thanks for the suggestion.
Old Jul 31, 2013 | 02:57 PM
  #467
Matlangevin07's Avatar
mine was doing this so bad, people thought i was trying to race at lights and showing off, car would stall every third or fourth light, it was bad, took my intake off, had a bunch of grease and oil inside , had alot in the tb also, cleaned both of them, car runs like a charm now, doesnt jump, no stalling, gas mileage is much better, easy 30 min job
Old Sep 3, 2013 | 01:54 PM
  #468
craigs06ls's Avatar
ok guys i attempted to do this in a very short time period today and didnt get the tb off due to the electrical connector...... how do i get this off...i didnt want to force because of time so i cleaned what i could clean with it on car until i can get it off....but it does seem to idle better...my problem was with the ac on.....so if somone could help with the connector that would be great...
Old Nov 20, 2013 | 02:48 PM
  #469
Icypuck17's Avatar
solid helpppppppppppp
Old Nov 20, 2013 | 05:09 PM
  #470
chris88z24's Avatar
Don't take the throttle body off.
Old Jan 4, 2014 | 04:06 AM
  #471
Bangtang's Avatar
Originally Posted by RedEcotecSS
mine only does it when the A/C is on. think it'd be the same problem?
Worth a shot. I'm gonna try. I will let you know!
Old Jan 9, 2014 | 06:29 PM
  #472
Coblt ss super's Avatar
I know this thread is still going on and i must post my story about my idle problem and car stalling like every 2 minutes at every red light. Well i cleaned my TB i cleaned the supercharger, i cleaned everything, i installed new O2 sensors(both), new plugs and coil packs and still would not fix the idle. Check your MAF sensor, mine was simply that and has been running great since. My 2006 cobalt has about 60,000 miles on it and thats when mine went but make sure to check that sensor, the only way i found out it was that was from my girlfriends father. Hes a big time Ford and GM mechanic, and he came up once and looked at it and found out it was that.
Old Jan 9, 2014 | 07:22 PM
  #473
chris88z24's Avatar
How'd you know it was bad? Just trial and error?
Old Jan 13, 2014 | 05:09 PM
  #474
Rambotk3's Avatar
I cleaned my throttle body last week and it is much better than it was before because it no longer drops low and bounces back up again, buuuut..... Now I have the same problem as you are having in the video where my rpms are hanging around 1500-1700 when I clutch in or pull it out of gear.. Not really sure what the problem is so if anyone else has any ideas to how to fix this that would be great!
Old Jan 14, 2014 | 07:09 PM
  #475
pretty much, i changed a bunch of things before hand and then i cleaned the MAF sensor and strted to work a little better so i decided to buy a new one and i did and when i installed it, it ran like new again
