Idle problem CURE!!!!!!!! Finally!!
Old Oct 30, 2012 | 05:42 PM
  #426
umrdyldo's Avatar
Originally Posted by 90white240
So I just tried it this morning and nothing its actually worse now lol does it take time to work?
Should work immediately. Try reseting the cumputer with a battery pull.
Old Oct 31, 2012 | 04:22 PM
  #427
90white240's Avatar
Tried it and cleaned my maf, works! Thsnks! Cheers!
Old Nov 15, 2012 | 06:58 PM
  #428
supercharged steve's Avatar
Tried cleaning the tb, changed the plugs, changed the maf and Still does it. Im gonna try replacing the timing chain. I have done the timing on it numerous times. Think it needs it at 108000 miles. Got a p0017 code too. Ill keep you posted on my idle issues
Old Nov 16, 2012 | 07:33 PM
  #429
MrSlickSter06SS's Avatar
Ima look into throttle control sensor as well see what that does ill repost here when i have an update
Old Dec 1, 2012 | 07:08 PM
  #430
Ok. Did the timing again. New chain tentioners and gears. Still idles like ****. And still has a p0017 cel. Anyone know whats up?
Old Jan 29, 2013 | 11:57 AM
  #431
574's Avatar
574
Old Feb 23, 2013 | 09:31 AM
  #432
ericgt79's Avatar
trying to get my tb off but i cant find where the connector comes off from or how to take it off. pissing me off. bad
Old Feb 27, 2013 | 10:16 AM
  #433
Bad-A-SS's Avatar
OK guts cleaned my dirty ass tb now my throttle is hanging wtf
Old Feb 27, 2013 | 06:56 PM
  #434
SalvageBaltSS's Avatar
you have to be careful with the butterfly inside, you probably bent somthing, even though it doesnt seem like it. I cleaned mine today, works like a charm thanks.
Old Feb 27, 2013 | 07:07 PM
  #435
Bad-A-SS's Avatar
Damn I probably did because the vacuum on decel isn't even the same anymore. Also I knock it out if gear and coast n idles at like 1200rpms until I stop rolling n goes to normal idle
Old Feb 27, 2013 | 07:32 PM
  #436
what do they usually idle at normal? cause mine is at like 900-1000rmps? but im super happy it doesnt jump like from 500 to 1300+ like before lol
Old Feb 27, 2013 | 08:06 PM
  #437
Bad-A-SS's Avatar
Yeah that's what mine was doing, but mine normally idles at 900.
Old Feb 28, 2013 | 12:52 PM
  #438
Bad-A-SS's Avatar
Anyway to fix that?
Old Feb 28, 2013 | 01:53 PM
  #439
Anyway to fix that?
what do you mean, fix what? i think the idle normal is at 900, so i think your good. lol
Old Feb 28, 2013 | 04:29 PM
  #440
Bad-A-SS's Avatar
Fix the throttle hang. It hangs at 1200-1500rpms while I'm rolling then when I stop idle becomes normal
Old Mar 1, 2013 | 02:04 PM
  #441
Bad-A-SS's Avatar
Can i bend it a little to maybe fix it?
Old Mar 1, 2013 | 02:06 PM
  #442
haha i wouldnt bend anything. if it hangs around 1200 then goes back to normal, you should be fine, but i wouldnt try bending anything, cause it might start idleing really low, or really high. lol
Old Mar 1, 2013 | 02:41 PM
  #443
Bad-A-SS's Avatar
I don't want to buy a new one tho
Old Mar 4, 2013 | 10:11 AM
  #444
Bad-A-SS's Avatar
Anyone?
Old Mar 4, 2013 | 10:19 AM
  #445
umrdyldo's Avatar
Anyone?
If you are talking about bending the throttle body plate, the answer is don't even think about it. You will not fix a high idle by doing that and will likely break the throttle body position. If you have cleaned the throttle body and it still idles high you either need to try a new throttle body, do a case relearn, or check for leaks.
Old Mar 4, 2013 | 10:23 AM
  #446
Bad-A-SS's Avatar
I'll post a video and you can see where it hangs ok
Old Mar 4, 2013 | 12:16 PM
  #447
Bad-A-SS's Avatar
Got the link for the howto on case relearn
Old Mar 4, 2013 | 02:29 PM
  #448
ya post a vid.
Old Mar 4, 2013 | 02:42 PM
  #449
Gelladuga69's Avatar
My car does what you're talking about. I thought I read it was normal.
Old Mar 4, 2013 | 03:44 PM
  #450
Bad-A-SS's Avatar
No it's not normal bc when I go to shift its like I'm dropping the clutch sometimes bc the throttle is hanging
