Idling lean- P0455
Idling lean- P0455
Hey, my car has been idling lean for a few days, we're talking like 17.0-18.0 AFR.
the code p0455 keeps coming up, which is a leak in the evap system.
The DIC told me to "check gas cap"
i got a new cap, and that didnt work.
not too long ago, i noticed the evap purge solenoid ticking kinda loudly... could this have died on me?
anyways...whats the part number on the evap purge solenoid?
any other common places i should check for leaks?
thanks
thanks
hm did you check your brake booster line, and your blow off line, actually all the vacuum lines and my hahn manifold the holes were a little loose around the two sensors, i had to get new gaskets for em to seal correctly...
sounds like a big leak
Last edited by hungryhip-ccp; Apr 3, 2009 at 01:44 PM. Reason: Automerged Doublepost
Im throwing a P0300 code after the install of the Hahn Stage V kit. Car idles like crap and I also am noticing a loud ticking from the evap hose and the module where the evap hose connects to if you feel it you can feel the clicking very loud. Anyone know anything about this??
PS. 60lb injectors by the way
hey guys, i just seafoamed the car and it is running a little better, but it is still idling at 16.5-18+ afr.
i have checked all sensors on the intake mani, and all the hoses i could see, and used the propane method for checking for leaks.
hungry, does your hahn intake mani squeak or squeal?
Bryan (06black) says its because its sheet-metal and something in it resonates.
anyways, does anyone have any ideas?
i have my new plugs in it, gapped to .030 and its still misfiring like a **** at idle to.
thanks
thanks
