if i go with a 2.6 pulley...
Old May 1, 2007 | 01:12 PM
InovatedSS's Avatar
and 60 lb injectors uinstead of the stage 2 3.0 and 40 lb injectors, will gm stilll flash the ecu ? i never put stage 2 in yet i bought it but i want a smaller pulley and bihher injectors, should i ever have bought the stage 2? what else do i need with the small pulley and injectors?
Old May 1, 2007 | 01:18 PM
SuperCobaltSS's Avatar
With 60# Injectors your going to need a custom tune anyway
Old May 1, 2007 | 01:23 PM
blown06's Avatar
if you are planing on doing 60's and a 2.6 you will be wasting your money on the gm stage 2 kit because the flash will not work the 60's you will need to get ahold of someone that can tune your ecu with hptunners. you will also want to get the supporting cooling mods
...... personaly if you want reliablity stick with gm stage 2 with a 2.9 pulley and call it a day because you are risking the potential of blowing the motor there is an issue with the #4 cylinder.... just remember you have to pay to play
Old May 2, 2007 | 09:24 PM
UNION30's Avatar
what stage kit would you go with and im not worried about warranty.
Old May 2, 2007 | 11:04 PM
Johnboy12358's Avatar
Well, recently there has been a discovery/thought/idea that when you up it to 60 lb injectors, you are causing the pressure in the fuel rail to be uneven. This causes the #4 cylinder to run lean, and pop. Its not just about warranty when you get down into the 60's and sub 2.7" pulley. Its more about if you want to have your number 4 not suck.
Old May 2, 2007 | 11:16 PM
Mattman6's Avatar
they will not give you the reflash unless you buy the stg 2 kit because it comes with a code for the dealer to reflash the ecm. You must use Hp tuners if you plan on going 60's!
Old May 2, 2007 | 11:41 PM
Shortbus's Avatar
Build your own kit is less expensive, just get 60lb injectors, and what ever pulley you want, and you need a custom hp tuners tune, and if your going with a pulley from 2.8 and down, if would be smart yo get some cooling mods, or you could have problems.
Builttss
Oct 4, 2015 10:21 AM
n20saturn
Sep 17, 2015 01:55 AM
Bluelightning
Sep 8, 2015 05:18 PM
Modernceo
Modern Performance
Oct 11, 2006 01:06 PM
