Important info for the 2.8 and smaller users!!
Old Feb 15, 2006 | 08:35 AM
FAST06SS's Avatar
I've found that when using a 2.8" or smaller pulley and 5K miles or more on the car, there could be some belt slippage. I have a CHEAP and very good fix for it so pm me or call me for details.
317-271-8346
Old Feb 15, 2006 | 08:47 AM
BlackSS/SC's Avatar
So whats your fix? I'd like to know cuz I'm about to order my Intense kit.
Old Feb 15, 2006 | 08:49 AM
memphisr24's Avatar
The pulley tensioner from zz performance works.
Old Feb 15, 2006 | 08:56 AM
BooSSted's Avatar
Just post up your fix.
Old Feb 15, 2006 | 09:04 AM
1stbluSS's Avatar
Yeah dude I would say post it. If it is the AC belt deal than that has already been posted. Why would someone waste a LD call when it can be posted or PM'D ?
Old Feb 15, 2006 | 09:18 AM
FAST06SS's Avatar
Guys, I CAN'T because i'm not a sponsoring vendor!! Thats common sense, sorry.
If you don't want to save money or make a phone call, pm me. It's not that hard.
Old Feb 15, 2006 | 09:37 AM
BooSSted's Avatar
Well is it something that your selling? if it is an idea that we can go out and get I don't think there is a reason that you would need to be a sponsor
Old Feb 15, 2006 | 09:51 AM
BlackSS/SC's Avatar
I found the pulley part number is Dayco #89009 will work.
Old Feb 15, 2006 | 04:05 PM
Rogue's Avatar
In working with Rob (Fast06SS) of Hoosier Performance we have come up with a short term solution to taking up the belt slack caused by running smaller supercharger pulleys. Ultimately a smaller belt is the correct solution however it may be awhile until one is found and they will probably be pretty expensive. This may be a cheaper alternative. Starting 2/26/06 INTENSE will begin shipping 3" supercharger tensioner pulleys.
The stock tensioner pulley is 2.5" and because of this the supercharger tensioner bracket will need to be clearanced a bit to make the oversized pulley fit. This is very easy to do requiring a T40 and T45 bit, a few minutes of time and shot of spraypaint.
Click the picture for the link to the pulley and pricing will be $19.99.
Old Feb 15, 2006 | 05:05 PM
ENUFPWR's Avatar
Thumbs up
Thanks Todd,
I just ordered that pully from you a few minutes ago. If you need that program I mentioned on the phone, I can probably send that to you. Only thing is I don't have access to the OBD2 cable required to calibrate from in the car. I'm working on getting one of those for myself to do some tunning.
Old Feb 15, 2006 | 07:35 PM
FAST06SS's Avatar
Thanks Todd,
And to reiterate, this is an easy 20-30 min job to install. If you are unsure, i will do it for you at my shop or via mail it to me and i'll send it back the same day. Call me if you have any questions.
Rob
Old Feb 23, 2006 | 01:15 AM
BlAckOnBLaCK's Avatar
What exactly needs to be spray painted? Also, what do you need to grind down to get this to fit? Thanks
Old Feb 23, 2006 | 01:25 AM
BoomInIt's Avatar
You have to grind down the tensioner pully bracket so the bigger idler pully can spin freely. Its easy took me 10 min using a dremel tool. I didn't paint mine, but you can if you want to. The pully covers what you grind anyway.
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
