INFE's Turbo Build
Old Sep 26, 2009 | 07:40 PM
  #101
damien's Avatar
Originally Posted by elecblue06
wow.. you really think that ? i don't anyone will walk any one else.. but the lnf should win
Meh, could go either way. LSJ has the advantage of longer gearing and higher rev limit. LNF has the advantage of the cam timing, which can play a crucial role in how well it'll spool.
Old Sep 26, 2009 | 08:24 PM
  #102
EXsoccer1921's Avatar
gearing is the other way around my friend
Old Sep 26, 2009 | 09:00 PM
  #103
elecblue06's Avatar
exactly lnf has better gearing better cam timing and probably more timing due to DI
least i'm not the only one who's not blinded by the almighty lsj lol .. the only things turbo lsj's have on lnf's is the 400 whp barrier and at 18 psi the person closer to that will be the lnf..
Old Sep 27, 2009 | 07:44 AM
  #104
06blackg85ss's Avatar
You do know mikes car is running 26psi right. Chris's car is still on the stock clutch, open diff, and stock axles. Mezz's car is defintely over 400whp I don't think it would be much of a race at this point
Old Sep 27, 2009 | 10:56 AM
  #105
damien's Avatar
Oh, whoops
Old Sep 27, 2009 | 12:33 PM
  #106
elecblue06's Avatar
hell even if they were at the same psi i'd venture to say the ss/tc would win
Old Sep 27, 2009 | 12:41 PM
  #107
gwatson650's Avatar
me gusta
Old Sep 27, 2009 | 12:51 PM
  #108
Nussle's Avatar
so this makes me wanna blow my 7k christmas bonus to turbo my car this winter. not good. lol
Old Sep 27, 2009 | 05:49 PM
  #109
INFE's Avatar
Well we tryed to turn the boost up and found some boost leaks so im gona try and sort them out over the weekend and then try again
Old Sep 28, 2009 | 06:28 AM
  #110
yeah, get that crap sorted out and we'll have another go at upping the boost. At least it's setup for it so you can test it out once you go over all the piping.
I'd check that intake mani and if anything put some sealant on the flange to the head.
Old Sep 28, 2009 | 12:58 PM
  #111
hungryhip-ccp's Avatar
yeah from what i have seen, by the snypse car at 22psi they were only able to make 371/383 and thats on a decent size turbo, quite a few lsj's have surpassed 400 on 22psi or less
from what i understand the lsj head flows better stock for stock. i may be wrong i dont swing from the nuts of a lnf and i dont enter that section often
lsj will go 7400-7500 all on stock valvetrain
hb ss/tc destroyed his head trying to run 7200rpm on a lnf
like i said it was imo, which im entitled to have right?
Old Sep 28, 2009 | 01:19 PM
  #112
elecblue06's Avatar
there is no lnf nutswning.. .. just because synapse had some issues pulling the power out.. right when these cars first came out doesn't mean people are still having issues... and just because one person destroyed his head doesn't mean everyone will...
yup you are totally entitled to your opinion i just think you shouldn't make judgements based on a few situations
Old Sep 28, 2009 | 01:26 PM
  #113
eh synapse car was only running a gt2871r.
I had my LSJ up to 8k rpm (on accident) on the stock valve train, still fine to this day (heads on another car now).
22 psi doesn't really mean much though, need to get more in to what size turbo they were running, hell I can make 400+whp on 15 psi on a 72mm turbo.... lolz
and kyle, stop with the LNF harrassment man, that's my territory.
Old Sep 28, 2009 | 01:36 PM
  #114
elecblue06's Avatar
hahaha sorry i'm not working i need something to entertain me lol
Old Sep 28, 2009 | 01:39 PM
  #115
wasn't talking about on here.
I've been having some things get back to me lately I haven't been to happy about. I told you the deal when you started doing the trifecta stuff. Please stick to it.
Old Sep 28, 2009 | 01:46 PM
  #116
INFE's Avatar
Well synapse ran a 2871 which is a T2 turbo thats y they did break 400. Im running a T3 3076 which is a pretty big difference and mezz is running the 3076 also and i bet hes over 400whp
Old Sep 28, 2009 | 02:02 PM
  #117
damien's Avatar
Garrett turbos are just too expensive for me. then again I want a FP unit which is right up there.
Old Sep 28, 2009 | 02:06 PM
  #118
daythecountrydied21's Avatar
7k bonus jesus christ get me an application .
you can make a basic kit for like 2k..then there's all the supporting things you gotta worry about which is why i haven't switched yet .
Old Sep 28, 2009 | 02:10 PM
  #119
fp's ain't bad at all, but you won't get the response the DBB units give.
Old Sep 28, 2009 | 02:18 PM
  #120
damien's Avatar
Maybe i'll build the first fp green cobalt. I'd like to do holset style like dan back in the day, but one of those mothers won't fit
Old Sep 28, 2009 | 03:26 PM
  #121
i did nt say your were nut swinging, i meant i dont know a whole lot about the lnf, i focus on the lsj because i have one,
but i also thought snypse was running 3071 so i was wrong there. i only watched the vid once a while ago. 2871 is pretty dinky
and agin it wasnt a judgment it was my foreseen outcome... i dont hate on the lnf i like that the block is stronger!
i totally im not gonna waste energy on the whole lsj vs lnf they both are great platforms for decent power
i was basically just stirring the pot a little by throwing out there that i personally think turbo for turbo psi for psi stock head for stock head i think the lsj will prevail
i know i flow more ve/lbs min than them... and i walk tuned lnf's easily on 18psi and ther spiking 25 holding 21-22 (yes i know 20g vs k04)
Old Sep 28, 2009 | 03:40 PM
  #122
go with a bullseye/borwarner setup man. They are journal bearing, but spool the same if not faster and make more power than their dbb counterparts.
Old Sep 28, 2009 | 03:45 PM
  #123
And they are nearly bullet proof!!!
google s256 vs 30r
the 30r hits harder but other than that they are side by side till the end and the 30r is not serviceable (must do a whole chra) and cost much more to maintain
Last edited by hungryhip-ccp; Sep 28, 2009 at 03:51 PM. Reason: Automerged Doublepost
Old Sep 28, 2009 | 03:52 PM
  #124
I almost scooped up an s475 for my RX-7, but decided to lower my power goals from 750+whp to 550whp and went with a gt3582r lol. wanted the car a bit more streetable.
Old Sep 28, 2009 | 04:13 PM
  #125
damien's Avatar
very similar indeed, minus the lag from the s256. I'd do that if I twincharged but for straight turbo i want something that would have full boost by 4500 latest.
