Informational: How not to make a timing table
Old Oct 26, 2012 | 02:26 PM
boostedpattywagon's Avatar
The following tune was pulled from a fellow LSJ member
It doesn't matter if your running 12 PSI or 30 PSI, this rather important portion of your tune will lead to your short block's demise.
Now those of you that tune LSJs, forever remember this. THIS IS NOT A SAFE TUNE JUST BECAUSE IT SAYS 22* BY REDLINE
MODS... this had to be done... this is one of just a few I've pulled of this tuner. This type of tuning is not acceptable
This is off another car CCSS3 tuned
Here's what the maf table looks like
This is what a timing map should look like
Old Oct 26, 2012 | 02:31 PM
Chevycobaltss3's Avatar
So now your wanting to start more **** huh? Considering the fact that I myself ran more timing midrange and wot I'd say this wasn't that aggressive (top end) his midrange is also less then what I usually give. There are many fellow Lsj owners with more ten this.
Thanks good by
Old Oct 26, 2012 | 02:34 PM
I'm not stupid this is blues car. I even stated many times his timing was ramped from the midrange to the 22 up at top end. It ramps down, say what you will but I have guys that have dynoed and showed improvements like so...
100% METH's Avatar
Wow dude...
this is unacceptable... how could you even put this on the guys car? It's not even smoothed :/
This tune is by no means safe... the amount of cylinder pressure on blue's car @ 25 psi and 29* of timing... it doesn't matter if your running 22* up top...
Old Oct 26, 2012 | 02:36 PM
mkulrey13's Avatar
Pleass's Avatar
Old Oct 26, 2012 | 02:37 PM
carstedt's Avatar
lmfao^^^
Sox-Fan's Avatar
Got Brakes?
Anyone want to explain what this is and why it's bad? Maybe educate the rest of us a little?
Old Oct 26, 2012 | 02:38 PM
carstedt's Avatar
x2
Old Oct 26, 2012 | 02:40 PM
Dart_SI's Avatar
Subd
Lmfao..
29* where? Oh midrange at 3700-4k. Sorry but he wasn't seeing 25lbs there.. He was seeing 25 way later
Old Oct 26, 2012 | 02:42 PM
100% METH's Avatar
4300-4600 RPM he's seeing 29-28 degrees... peak torque is between 4500-5000 on a 2.7 TVS SETUP
Old Oct 26, 2012 | 02:44 PM
The accusation here is (to much timing midrange and not smoothed) considering this car build boost in rpm it's not much) boost isn't controlled by a wastegate in the exhaust now is it. So it's not automatically 25lbs at 3k-4k. His midrange timing at higher cyl pressure is 29-27 (midrange) and tapers to 25 then to 23 then to 22 at his redline.
Old Oct 26, 2012 | 03:05 PM
100% METH's Avatar
There is a map above showing how a properly scaled timing table should look.
Old Oct 26, 2012 | 03:06 PM
Pleass's Avatar
Bpack locked tvs thread ahhh
Area proved him wrong so he got mad
Old Oct 26, 2012 | 03:08 PM
BPacak's Avatar
Vtec Rep
-___-
Old Oct 26, 2012 | 03:10 PM
100% METH's Avatar
let's leave this in the TVS thread please
this thread is black and white information only
Tjolley's Avatar
dude my e70 tune runs 25* up top...on a 2.8 pulley...
e85 is 29 up top...
Team SS's Avatar
TTR Powered
Originally Posted by BPacak
-___-
I know how you feel
Old Oct 26, 2012 | 03:12 PM
BPacak's Avatar
Vtec Rep
can we talk about how you have multiple accounts....
Old Oct 26, 2012 | 03:13 PM
100% METH's Avatar
only accounts I have are Steven Flit & 100% meth
Couple years back I decided to change my sn to avoid my actual name being on the internet.
I pm'd a moderator in the past to have my other sn deleted, but had no response.
thedubsack85's Avatar
Old Oct 26, 2012 | 03:14 PM
BPacak's Avatar
Vtec Rep
what about boostedpattywagon?
Old Oct 26, 2012 | 03:15 PM
100% METH's Avatar
I didn't make it
If you have the power to do so, please delete Steven Flit from the forum. Or at least point me in the right direction to do so myself. It's been inactive for 2 years
He is sharing my photobucket photos though
Old Oct 26, 2012 | 03:16 PM
carstedt's Avatar
so how do you determine the amount timing is ran on a setup? will it start to knock when it gets to much or to little? trying to understand this! so answers and good info are always appreciated
