Ingalls ED makes my engine louder?
Originally Posted by Mercury
My brace isn't too tight, it is at the setting it was at when I took it out of the box. If it was too tight, I'd just be spinning wheels right?
Ide like to see this come to cecil on sat they are having a party and stuff
well take you down the 1/4 and if you run 14 flat nothign is wrogn damnit
lol
Originally Posted by 2K5SS/SC?
It's a engine damper, i.e. no more wheel hop!
Originally Posted by cvenom2122
Jeremy had to pplay with his a lil to get it on correctly
lol
lol
I have no problems like merc described. When you layed the dampener up against the 2 braces that where supplied after you screwed them down did the holes of the dampener line up 100% perfect with the holes on the brace, or did you force them to fit? I had to do much adjusting to get them just right.
I have a problem with noises. It definately fixed wheel hop and have no problems down low but I hear/feel under my foot vibrations when I accelorate from 2000-4000 rpm and also when taking a turn hard. It still accellorates and turns fine I just hear noises at htose times. Is that normal?
See what I'm afriad of is this problem I'm having now won't let me be fast at all haha! I guess I can unhook it at the track. Is this party at night? I really hate going to cecil on the weekends but I might go
The noises I now know are normal, basically the motor now has a direct metal connection to the frame which could cause all sorts of noises
The holes lined up perfectly.
Originally Posted by FLCobalt
ok so repeated what part it is and what effect its soppose to give. but you still didnt technically tell me what it DOES
Originally Posted by Tomtwtwtw
Someone correct me if I'm wrong, but it basically takes away the flexibility of the stock motor mounts, so the engine doesn't twist when you launch. The mounts are soft for comfort and quietness, which I'm sure is great for the 2.2 models, but it hurts our cars' performance.
Ben
Alright, at this point I have no problems with the Ingalls at all.
Actually it has completely changed my driving experience.
*Shifts are noticeably smoother
*Eliminates this shaky occurance that happens between 1st to 2nd gear
*You notice the power of the car more due to the thrusts and shakes that are now apparent.
Mine shows up tomorrow and I cant wait. I have the RSM Tranny mount too so these 2 together should take away all wheel hop. I get vibrations now but im used to them so no biggie. The rsm pretty much took care of like 80% of the wheel hop but this looks kewl under the hood and any extra cant hurt.
You need vibrations lol, this isn't a luxury car! its a quick little "race car"
I actually hated how quiet the car was when I first got it, now it is just how it should have been!
I got my dampner from Turbotechracing.com! I HIGHLY reccomend them as they have the best prices and customer service from any store I have ever dealt with!
Well...you're still only bracing one side of the engine. The other mounts are just as crappy as the top one you'd be replacing. Hopefully tomorrow I'll be able to open the door to prices you won't believe on this stuff....just waiting for a paypal addy to mail vendor payments to....
And to answer your question, if you're running hard you should be using both a dampener and motor mounts.
