Ingalls ED makes my engine louder?
Originally Posted by uthinkimodd
you may be getting more vibratioon that could translate into some noise other than that it shouldn't have any direct reason to make your engine louder
I did my car when I installed my damper and motor mounts and the difference between Dynamat and not is like night and day..hope theis helped..
also if you have any ?'s email me
robs@ingallseng.com
Originally Posted by Xenozx
I have no problems like merc described. When you layed the dampener up against the 2 braces that where supplied after you screwed them down did the holes of the dampener line up 100% perfect with the holes on the brace, or did you force them to fit? I had to do much adjusting to get them just right.
I have a problem with noises. It definately fixed wheel hop and have no problems down low but I hear/feel under my foot vibrations when I accelorate from 2000-4000 rpm and also when taking a turn hard. It still accellorates and turns fine I just hear noises at htose times. Is that normal?
when you install it make sure your eng. is in nuetral and that you adjusted the length of the damper so it lines up with the holes before you attach it.also another important matter is making sure you have the brackets as parallel as possible to the motor mount..
Originally Posted by cavy9psi
where did you guys order this from ( Ingalls ED ) THANX
Originally Posted by Cynic/Torque Forward
Well...you're still only bracing one side of the engine. The other mounts are just as crappy as the top one you'd be replacing. Hopefully tomorrow I'll be able to open the door to prices you won't believe on this stuff....just waiting for a paypal addy to mail vendor payments to....
And to answer your question, if you're running hard you should be using both a dampener and motor mounts.
I agree that you should run motor mounts also.....the damper takes care of eng. movement from front to back while the mounts take care of movement from side to side..
Also BEWARE OF IMITATIONS!! Ingalls engineering has been in business for over 25 years and is one of the orginators of engine torque dampers. We solely test, develop, and research our products extensivly to make sure that they are of the highest quality and actually work unlike other companies that are out to make a "quick buck" off the aftermarket.
Not only do we stand behind our products we actually use them on our own cars. I have had my damper installed for over 2 years on a boosted civic and love it! if anyone has any ?'s regarding our damper please feel free to contact me directly..
robs@ingallseng.com
No need to get into arguements...Ingalls has been doing this a long time and cynic/TQFWD has been doing these for the redlines/mazda's iirc for a long time. Both make a good product. I personally went with ingalls and had problems but they took care of me with top notch service!!!! (the wrong directions/washer thing). I know I'll be coming to cynic for strut braces and torsion beam stiffeners. Point is both make great products just execution is different...I just happen to like the ingalls style design.
Dan
Dan
Ah yes...the old "the other guy's product can't possibly work" bash. I let my reputation speak for itself
ahh ok..
I didn't bash you or the product..I welcome competition and feel that everyone on the cobaltss.net community does too...
I am just bummed cause you are going to Ingalls damper specific threads and trying to slang your product while bashing the Ingalls Damper in the process stating that the current design we are using is YOURS??come on..
pm'd
Originally Posted by max_boost
I'm glad you got top notch service because I didn't. Their solution for my damper problems was to drill the mounting hole out to make the damper fit. Great solution
I can send you one that is correct if you would like...
Originally Posted by robstamina
who did you talk to?
I don't have the damper anymore. The vender I bought it from allowed me to return it.
robs@ingallseng.com
Agreed...I'm not here to bash. I just don't appreciate propaganda pushed on me before I even have a chance to take off. I offered honest answers in my opinion for these vehicles. You'll go with whatever torque brace you feel is better. Sorry for the misunderstanding
Ben
Ben
shoot me an email and I will see what I can do to get you a free one in the name of customer service...
robs@ingallseng.com
robs@ingallseng.com
Ben
Ben
let's get an unbiased third party on here to do a review on the 4 different dampers for the cobaltss's and see what people find out and let the Cobalt community make the call..fair?
the catagories can be
1. price
2. function
3. and an actual "stress test" to see who has a better damper shock and brackets..
I think it would be fun and people can base their judgements off these findings instead of people bashing each other to sell their products...
let's start conversing pm btw..
Just got off the phone with Rob and he is going to do what he can do to get me taken care of. Thanks again.
got your email and it's on the way. I added some extra goodies for you too..
You got one of the production models that was "mistamped" without the correct hole pattern.. Our quality control got 4 of the 5 of the thousand+ brackets we did.. unfortunately you got the fifth one...i know that is no excuse but I just hope we can get you taken care of...
definitly contact me in regards to installing it and adjusting the preload and length...
Good talking to you..
Originally Posted by Mercury
I just installed my Ingalls ED and I love it, no wheel hop, no grinding noises.
BUT it sounds as if my motor is louder? Is this possible?
Ingalls Enigine Damper Trick no.1!!
Dynamat used for subwoofer enclosures is great to decrease vibration and noises throughout the car especially when you run the "Stiffy" damper on the hardest setting.. Cobalts actually come from the factory with sound deading material installed around the strut area...use dynamat extreme on the firewall and the strut area..even over the factory installed dynamat material..I would recommend dynamat extreme cause it has higher temp ratings than regular dynamat..you can really go crazy with this stuff depending on how crazy you want to get to decrease vibrations..
hit me up guys if you have questions like this..
robs@ingallseng.com
link: http://www.turbotechracing.com/produ...idproduct=4591
what is the deal with all of u guys being so gullable. who is to say that robstamina is even from Ingalls?????? anyone with a decent IQ could pull this off..... not to discredit rob, but im sure you see where my concern is coming from.....
edit: i retract a bit of what i said after seeing some other posts from robstamina. appologies
Originally Posted by TheExorcist
o yes, Rob most definately works there....I talked to him yesterday morning with questions about my Ingalls.....Amazing product guys!
Originally Posted by ReMz
bought mine from turbo tech.... after talking with Aaron via email for quite a while, i have to say they have the best customer support from any site i have visited.
go to our site or call me...
robs@ingallseng.com
1.800.641.9795 ext23
or
http://www.ingallseng.com/parts/stiffy.htm
link to my email is at the top of the page..
I am curious if you think I work for a vendor on here or something since I didn't see your retracted comments..
ALso are you in ColoRADo? I saw on your location listing USA CO so I am wondering.. if so we need local test vehicles and also do alot of local drag/scca/ shows locally that you should check out..also a bunch of car meets fri-sun in Denver...
