Ingalls ETD adjustment
Old Feb 1, 2008 | 02:35 PM
ikeryder13's Avatar
I just installed my ETD that i got from a friend for 60 bucks... Yeah i know... He is getting rid of his redline... I just needed to know if it is normal for the car to shake alot after installing it... where to most of you guys have it set for normal driving..
Old Feb 1, 2008 | 02:38 PM
D4u2s0t's Avatar
i have it on the tightest setting. and yea it's normal. try putting it to 14 or 15mm if you want less shaking, and tighten it up more for the track. i think mine is set at 10mm. i don't even feel it anymore along with the tranny mounts. got used to it.
Old Feb 1, 2008 | 02:41 PM
ikeryder13's Avatar
if i lighten up the tighteness will it be more prone to bend?
Old Feb 1, 2008 | 02:42 PM
an0malous's Avatar
as long as you do your adjustments properly it wont bend. unless you try to launch like an idiot.
just make sure that when you are adjusting, you unbolt the rear bolt holding the shock to the bracket.... adjust the damping, then readjust the shaft length to line back up with the hole, before rebolting it in there.
this is 90% of the cause of bent brackets IMO.
Old Feb 1, 2008 | 02:44 PM
D4u2s0t's Avatar
shouldn't be. you have to take off one end to loosen/tighten it though. don't adjust it will it's still bolted on both sides.
woops, beat me to it
Old Feb 1, 2008 | 03:04 PM
Kaisoboy's Avatar
Got mine set to 12 mm. No vibration and no wheel hop. Anom is right though. Make sure you adjust everything properly and you should have zero problems.
SmitBag
Sep 7, 2016 08:05 AM
toysareforboys
Nov 17, 2015 05:22 AM
justinchinn
Oct 2, 2015 12:18 PM
The Rookie24
Sep 20, 2015 04:33 PM
brett.higgins3
Sep 14, 2015 01:48 PM
