injector identification
Need some help
Bought used injectors as 42lb and going through the p/n I believe there 79lb can anyone verify this for me
P/n 01D129B
http://www.racetronix.biz/itemdesc.a...1D129x&eq=&Tp=
P/n 01D129B
There def the 75/79 but the thing that concerns me is are they the same ones paul uses... If not he is going to need the flow rates on them to tune it properly.
So the question is ... Are these the same as the racetronics 79's ??
Ahhh I see what your saying is there a way that we can use the flow rates he has to get like a base line...and if it runs shityy we can send him like the idle and he can adjust it accordingly? Sorry if I'm wrong new to the whole tuning/fuel injection life lol learning abs figuring it out as I go lol
theres good info on getting offsets correct on the hpt forum. look up cobaltoverbooster's lsj guide and lwrs10's posts. the flow rate wouldnt be hard to estimate considering that it is a linear function
if they are 79s from racetronix, a trick that many used to do in the past was take the gms2 fueling tables and set the multiplier to 1.8 across the board as a good starting point. if you do install them, please comment on how they idle. because i have been wondering about these for a while
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Nahh it's for my car lol what do you think they are 75/79s or 42s? From what I've seen looked into they look like 75-79s
