Injector quesion
Old Oct 10, 2009 | 10:54 AM
MikeyB's Avatar
Injector quesion
I bought my car from GM with what they said was GM stage 2
It had the black stage 2 pulley with the blue bolts.
How ever a GM dealership riped a part my car, to the block to fix it, but only after they sent the cyl head out did they check the PCM and it came up as a non GM calibration
So i looked at the injectors and they are made by siemans
I will get a pic later, i cant read a full part number other then 1610 - something on them it says "Siemans Deka" on them too
there short and stubby and have a silver /gray band at the bottom.
Old Oct 10, 2009 | 10:57 AM
Jrhdpaintball's Avatar
how much boost were u getting before?
Old Oct 10, 2009 | 10:59 AM
MikeyB's Avatar
just under 15psi on a 2.9 10.0 AFR could of been lower but the AEM only reads to 10.0
Old Oct 10, 2009 | 11:16 AM
Josh@ottp's Avatar
Those are Siemens 60lb injectors.
Old Oct 10, 2009 | 11:17 AM
StageII07's Avatar
Could it be that somthings just wrong with your PCM that is reading not GM Calibrated or w.e..or somthings wrong with there computer.. orr or or..just maybe there lying to you?..lol
and as far as the injectors..those arnt stockers..=] lol
Old Oct 10, 2009 | 11:37 AM
MikeyB's Avatar
I know there not stock, i have a 2.9 they cant be stock...
And yes the are lying to me, they destoryed the engine and gave it back to me in a box and everything was in the trunk.
They voided my warranty because of this non GM calibration, so i had to have my car towd home with no engine.
Fast 98, how sure are you that they are 60's? dont mean to be rude, just so i understand why better
GM flashed my car to stock tune, so i have to have a custom tune once the car is rebuilt
Old Oct 10, 2009 | 12:00 PM
WickedSS2005's Avatar
They sold it to you as stage two? Sucks, but you may not have much of a case. Proving that you didn't do anything after buying it is going to be tough.
My Siemens 60's were long, skinny, and black. These sound different, atleast from what usually are bought thru your shop Josh. I'm not doubting you. Just seems funny that it's a short stubby gray injector
Last edited by WickedSS2005; Oct 10, 2009 at 12:00 PM. Reason: Automerged Doublepost
Old Oct 10, 2009 | 12:04 PM
MikeyB's Avatar
Yeah, did siemans even make 42's??
Yeah they said it was GM stage 2, but the car was owned by GM before, it was used as a track car by GM, according to GM VIS.
But what ever. **** happens, i get to finally learn how to rebuild an engine
Old Oct 10, 2009 | 12:56 PM
Josh@ottp's Avatar
http://www.fiveomotorsport.com/Parts...ns109958_8.jpg
Some siemens 60's did come with the grey bottom.
Old Oct 10, 2009 | 01:56 PM
MikeyB's Avatar
They look close to that, ill get a picture later.
Old Oct 10, 2009 | 02:18 PM
Stiner's Avatar
look like these?
Old Oct 10, 2009 | 02:32 PM
elliottSS91's Avatar
are you serious just under 15 with stage 2?! i only have an intake and ported blower and im pushing almost 15!!
Old Oct 10, 2009 | 02:34 PM
MikeyB's Avatar
in that pic above the gray band is silver, on mine that is black but other then that they look just like those.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
