Injector size
Old Mar 15, 2010 | 01:13 AM
ztkells's Avatar
Injector size
I'm wondering if I do a 2.8 setup, full catless 3" exhaust, h/e, ported m62, e85, and CAI. Would 60lb injectors be good enough to where I wouldn't be maxing them out? I've seen a bunch with only the 60's but am curious if I should just get the 80lb ones if I am looking at those mods alone and especially with e85. Thanks.
Old Mar 15, 2010 | 01:20 AM
GM>urpos's Avatar
80s for e85
Old Mar 15, 2010 | 01:27 AM
ChevyRockstar's Avatar
i'd go with 80s
Old Mar 15, 2010 | 11:03 AM
skatin_boarding's Avatar
If your planning on e 85 you'll need the 80's. If you only use gasoline, 60s will be plenty.
Old Feb 9, 2012 | 01:03 AM
Black Napkin's Avatar
you can use 60s and be alright. i do and other people do.
Old Feb 9, 2012 | 07:38 AM
zfissette's Avatar
always use 80s, they only cost 5 bucks more a piece and rock. this is not a situation where you want to try and get away with less. the 80s can be tunes to make your idle fine with a few simple adjustments.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
