Injen CAI 2.0 just came
Old Jan 28, 2006 | 10:42 PM
gonzo's Avatar
Seems like most people are having the rubbing issue, I have it too. What did you think about the new throttle response?
Old Jan 28, 2006 | 10:44 PM
Nuclear's Avatar
I had the same scratch on the top of my intake from the lift cylinder for the hood!
Old Jan 28, 2006 | 10:50 PM
MarcS's Avatar
The Stig
I can feel and hear an improvement.
I couldn't stop slowing down and downshifting to 2nd and hitting it. It actually sounds like it's supercharged now
Old Jan 28, 2006 | 10:51 PM
MarcS's Avatar
The Stig
Find any fix for the problem?
Old Jan 29, 2006 | 02:33 PM
CobaltSS313's Avatar
I have a K&N but i know, nothing beats the sound of the supercharger
Old Jan 29, 2006 | 03:09 PM
silverSS's Avatar
Post pics with it installed!!!!
Old Feb 2, 2006 | 01:46 PM
MarcS's Avatar
The Stig
I put some black electrical tape on the top of the tube so show where it's rubbing.
You can also see where I used a grinder to shave down the bracket on the hood.
I did not use the rubber bushing supplied by Injen. It gave better clearance in the fender without it. Not using it may have affected the clearance under the hood though.
Old Feb 2, 2006 | 01:50 PM
retrop's Avatar
I never noticed that mine hits the hood. But jsut below where that ground screw is that you have capped beware cause i noticed mine rubs the frame right there and it can work a hole into the intake. There doesn't seem to be any way to turn the pipe to not get it rub so i just put some rubber tubing between the intake and the frame.
Old Feb 2, 2006 | 07:01 PM
05OrangeSS's Avatar
Mine also rubs really bad on the hood prop, I'm gonna call them tomorrow and see if there is anything they can do to replace it or something so they don't wear a hole through the tube. If anyone else is having this problem you should post it in here because I'm going to refer to this website and this thread so they can see that it's quite a common problem.
Old Feb 2, 2006 | 07:24 PM
plyboy-illest's Avatar
loosk sweet in black!! im still in the middle of deciding between the K&N or the injen for my ss\sc
Old Feb 2, 2006 | 09:22 PM
  #36
Fast Freddy's Avatar
I just installed the black injen intake today... looks great but my air filter hits the inner ground effect and pushes it out slightly right under the left headlight. anyone else have this problem??
Old Feb 2, 2006 | 09:27 PM
  #37
MarcS's Avatar
The Stig
That is why I decided not to use the injen rubber bushing. I had better clearance w/o it.
Old Feb 2, 2006 | 09:51 PM
  #38
NJBLUESS's Avatar
Thanks for the heads-up on some fittment issues. My intake should arrive Friday or Sat. and I will attemp to find a way to work around those issues. Possibly enlongating the slot for the mounting screw?, seems like that may lower the tube enough to clear the hood. As long as it does not begin to hit the inner fender. The ground stud you could just cut flush with the nut.
Old Feb 2, 2006 | 09:59 PM
  #39
MarcS's Avatar
The Stig
No problem. I suggest shaving the ground screw and caping it like I have because the tube will rest on it.
Old Feb 2, 2006 | 11:38 PM
  #40
kraker's Avatar
How much did it cost? Will putting one of those on Void the warrenty?
Old Feb 2, 2006 | 11:46 PM
  #41
MarcS's Avatar
The Stig
Cost $243 shipped. It will not void your warranty unless for some reason it implodes and destroys your engine (not likely).
Old Feb 3, 2006 | 12:23 AM
  #42
djt81185's Avatar
Originally Posted by Doc
yes he will....he'll roll the window down just to hear the whine even when its 30 outside
You will..I know I do
And my first thought when I saw this thread title was
Well don't just stand there clean it up!
dat dat ching...I'll be here all night folks
Dan
Jan 12, 2016 12:01 AM
HEATON
Oct 16, 2015 07:21 PM
717ssbalt
Oct 2, 2015 04:01 PM
Sep 28, 2015 12:51 PM
