installing endplate, change gasket?
Old Jan 26, 2010 | 07:08 PM
chevysssc's Avatar
Question installing endplate, change gasket?
im having a ported head put on the car and figured id have them throw on a dual pass now my question is can i reuse the gasket or buy a new one?
Old Jan 26, 2010 | 07:10 PM
ItalianJoe1's Avatar
it's an o-ring, totally re-useable.
Do you already have an endplate?
Old Jan 26, 2010 | 07:28 PM
chevysssc's Avatar
yes i do i got one from a friend for 50 used couldnt pass it up
Old Jan 27, 2010 | 08:58 AM
mrbelvedere's Avatar
take it to a machine shop and have them mill it so its flat
Old Jan 27, 2010 | 09:43 AM
selfinfliction's Avatar
uhhh what? he doesn't need to do that
Old Jan 27, 2010 | 12:59 PM
SSfamilywagon's Avatar
The o-ring gasket can be reused if it doesn't get taken off the intake manifold. Once it comes off, it stretches and is a bitch to put back in. I had to replace mine cause it wouldn't stay in place and seal.
Old Jan 27, 2010 | 03:23 PM
Frew's Avatar
mine came off, yea it is a bitch to get back on but totally possible to get it back in the groove, use the old one, or buy a new one off me
Old Jan 27, 2010 | 07:05 PM
mine was warped and they do warp
Old Jan 27, 2010 | 07:16 PM
if your endplate was warped, either something dumb was done to it or you got some really serious effin issues.
Old Jan 27, 2010 | 07:39 PM
if something dumb was done it would have been done at the factory its alluminun with a very thin sealing edge after many heat cycles will warp it then when u unbolt it your fucked it wont hurt to check and mill if needed
Old Jan 27, 2010 | 07:46 PM
As far as the o-ring stretching, Protip: put it in the freezer for 15 min. Shrinks right up.
Works good if you don't have the paitence to put it back in carefully, I've never had to replace one on any of the installs i've done for people, they go back in just fine.
As far as the endplate warping: I've checked a couple of them for flatness when I get the cores back, none have ever been out enough to cause an issue. Also, as you mentioned, it has a thin sealing edge (relatively speaking, it's about 5/16" thick at the narrowest, and has plenty of structure, not gonna warp easily at any rate), so if it is a little out, it will pull down within reason.
Old Jan 27, 2010 | 07:48 PM
heat cycles? the endplate has coolant running through it constantly the endplate is also not "thin" by any means. go ahead and stop now before the hole gets too deep.
Old Jan 27, 2010 | 07:55 PM
Yeah, I was gonna touch on that as well. Unless your ambient temps are below 0F, i'd highly doubt that plate will ever see a 100 degree swing. Definatly not enough to warp a cast piece like that. Especially since it will be evenly applied.
Old Jan 27, 2010 | 09:41 PM
well tell that to mine then i had to get it milled because it wouldent reseal it was warped and it will get over a 100 degrees
Old Jan 27, 2010 | 09:48 PM
chevysssc's Avatar
i will be sure to check this
Old Jan 28, 2010 | 06:17 AM
100 degrees isn't going to warp that thick of aluminum
hell during the summer it stays over 100 degrees for months at a time lol
Old Jan 28, 2010 | 08:45 AM
lol smart ass
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
