Installing Meth Kit: Help w/ Switched Source
hey guys,
im going to be installing my kit this weekend...anyone know where i can tap to get a 12 v ignition source?
or preferably a fuse that i can use in the fusebox under the hood with an add-a-fuse?
thanks guys!
thanks guys!
I tapped into my fuse box on the passenger side, I used the H-vac 10amp fuse, works like a charm.
I could take pics when i get off work if you would like.
Its also very easy to hide, plus you have to use a fuse that only gets power when the key is turned on.
Hey invisible can you send me a detailed how to on your meth injection instalation?
Perhaps if you took any pics but a simple write up would be great!
I've only talked with people for months about it but I now have the money and want to take the dive.
Thanks!
Thanks!
Use a mini add-a-circuit from the local parts store and tap it into the black box under the hood. Easy day and easily removeable too if needed. If look in my gallery you can see where I mounted most of my stuff.
Yea I can take pics but ill write you alittle sumthing up also. When you get it in if you need any help, Ill be more than happy to help.
nope, probably the same- i have a fusebox by passenger side as well...problem is, i dont want to run another wire through the firewall if there is a perfectly good ignition source in the fusebox under the hood.
Nope your is different then mine, I have to run mine from the cab to under the hood because i have a controller for mine that is mounted in the cab and everything is ran off that. But there is a boot that goes through your firewall, its what i ran my map sensor wire through. But for you I agree just to keep it all under the hood.
even when the car is turned off
Sep 28, 2015 12:51 PM
