Installing Meth, Want Opinions On Best Place To Install Nozzle
Old May 6, 2010 | 02:09 PM
Bluelightning's Avatar
Got Bewst?
So i'm installing an OTTP Stage 2 kit on my car (as soon as they get modular pulleys, it's been 3 weeks now) and got a Devilsown meth kit i'm going to install. I've heard and read diffrent places to put the nozzle or nozzles if i choose to run more than 1. Just wanted to get some opinins in what some of you guys out there are running. Pre throttle body, throttle body and intake manifold, direct port ect
Old May 6, 2010 | 02:15 PM
coopercharge's Avatar
The OTTP Intake has a meth tap option and the intake is great and as you only have one main area just as well use the intake piping as the water can cool the supercharger as well at this point. Multiport works really well for turbos because the intake manifolds have 4 port tubes going to the main intake where the throttle body is connected with the supercharger the intake is 1 solid piece. Stick with a bung in the CAI you waont regret it.
Old May 6, 2010 | 02:29 PM
krazycobalt's Avatar
I would have to agreed!
Old May 6, 2010 | 08:07 PM
Got Bewst?
Does the meth play wear and tear on the throttle body and supercharger over time?
Old May 7, 2010 | 01:55 PM
farmerz24's Avatar
will you regret it when your tb fails over time due to the meth getting into the tb and screwing it up?
Old May 7, 2010 | 02:18 PM
Got Bewst?
Thats what i asked so explain how. Meth didn't wreck the TB on you're turbo cavi. Or maybe the motor just didn't hold togeather long enough haha
Old May 7, 2010 | 02:19 PM
I buddy that has a an ss has had the meth kit tapped into the CAI and never had an issue with it and hes been running that setup for almost 40,000 miles and no issues.
Wont hurt the throttle body or the supercharger. Nitrous on the other hand will eat away at the coatings on the props in the supercharger.
Last edited by coopercharge; May 7, 2010 at 02:19 PM. Reason: Automerged Doublepost
Old May 7, 2010 | 02:39 PM
cli3e0339384398jk's Avatar
Meth will also eat away at the coating, when i took my stock supercharger off for the TVS it had no coating left, the coating doesnt affect the performance though-that was only 3 months of injection( That seems to be the consensus anways on here) Im not sure about the TVS though with the coating, i havent taken it off since i installed it.
stew_pidaso59's Avatar
I have mine tapped into the CAI and have had zero issues with the TB or supercharger. been running it for about 30k....
Old May 7, 2010 | 05:01 PM
Kennyspec's Avatar
O ****......
Old May 7, 2010 | 08:35 PM
BlackBaltSw's Avatar
The teflon coating on the supercharger is to keep it quiet. And the OTT spacers threads are too deep for a devils own nozzle. I took my tb spacer out with the nozzle mounted on it and the meth could just puddle up and drip off. Mount it on the CAI.
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
