Installing stageII modular pulley - need help
Old Sep 12, 2006 | 01:48 PM
godsfshrmn's Avatar
We managed to go to the dealership and use their press to get the stock pulley off. Unfortunatley, their press was not large enough to press the new modular housing onto the s/c. How else can we get the housing on there? We are out of options
Old Sep 12, 2006 | 01:51 PM
NoRemorse's Avatar
Buy a pulley installer for power steering at autozone. Put a touch of engine oil from your dipstick on the shaft. Presto, just follow directions.
From my expierences it is A LOT harder to get the stock pulley off than it is to install one!!!!!!!
Old Sep 12, 2006 | 02:43 PM
godsfshrmn's Avatar
Was the s/c pulley in perfect alignment with the idler pulley? When we put the s/c back on it was off by a bit.
Old Sep 12, 2006 | 03:52 PM
toydriver00's Avatar
You can rent the PS tool from Advance Auto Parts for free (just a small deposit that you get back).
Old Sep 12, 2006 | 06:14 PM
fljohnboy's Avatar
Find a stud that will fit the supercharger snout with nuts and washers. Put the ring in the oven and heat it for about 20-30 minutes. Take ring out of oven and put on snout the washers then nut and tighten nut. The ring will go on very easy. That's the way I did mine. I used an air impact wrench and had it in in 10 seconds. You have to be fast so as to not let the ring cool.
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
