Intake Idea
Old Aug 29, 2007 | 01:39 PM
Deathcult's Avatar
Intake Idea
Well The Cold Air Intake.
Thats what I was thinking about for the past few days...
We have the Air Box Mod and the CAI's...
Well lets say we have the CAI and we want to put a 2nd one on there...Would it be harmful to the car.
And just so you know, I was thinking maybe drilling a hole and welding another pipe to the current pipe so there are 2 Filters sucking in cold air into the S/C instead of one.
I would think that would be to much cold air.
Ideas, Opinions suggestions please do so =)
Old Aug 29, 2007 | 02:08 PM
Belto's Avatar
well, some1 did it, he put a Y connector at the end, and said that the wine was way louder,,
but in flow of air,, is the same,, bc its going to the same diameter intake tube,, so you can do it,,, but it wont help in the HP
Old Aug 29, 2007 | 02:53 PM
DrPuttsSS/SC's Avatar
If you had a restrictive air filter, your idea might help. If you had an aftermarket filter that allowed enough airflow, 2 probably wouldn't do anything except give you more time between cleaning/replacement.
If one filter was in the engine compartment it would be sucking the hot air from there, defeating the purpose of a CAI.
And you can't get too much cold air, except maybe in winter!
Old Aug 29, 2007 | 03:02 PM
Frosty288's Avatar
If he sucked air from two different cold sources then he would be getting a lot more air. Doesn't matter if it's all connecting to the same tube, because the air will be moving much faster.
This is more beneficial to a turbo setup because it builds up more positive pressure before the trubo. Which mean's it doesn't have to work as hard to build up boost due to the increased air flow rate.
Old Aug 29, 2007 | 08:42 PM
Belto's Avatar
I disagree It will be entering the same amount only from 2 different sources, but I may be wrong,, hell is his car,, he can do as he pleases
Old Aug 29, 2007 | 09:28 PM
Deathcult's Avatar
well im curious to know on this theory. I would try it if it wont harm my car.
i dont want to break the car. i just want to make it sound sexy =)
while making it have that show look =)
Old Aug 29, 2007 | 09:42 PM
Belto's Avatar
ifs that what you want , you will get it,, and no it will not harm your car
Old Aug 29, 2007 | 10:05 PM
sick_ss/sc's Avatar
im the one that did the Y connector. dont do it ,it dont work throws CEL
Old Aug 29, 2007 | 10:06 PM
Belto's Avatar
there you go man He came in and answer your question ^^^
Old Aug 29, 2007 | 10:59 PM
Frosty288's Avatar
Hmm that's odd.
As long as I leave the MAF sensor housing alone I can do anything I want before it.
But then again I drive a Saab..
Old Aug 29, 2007 | 11:20 PM
sick_ss/sc's Avatar
man im telling you its like its getting much air. it really makes your car whine, but it makes it slow a fuking terd
06MetallicBalt
Jul 20, 2025 08:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
no_ss
Oct 18, 2015 11:58 PM
OrangeCoba
Sep 25, 2015 06:06 PM
