Intake Manifold won't budge!
Old Aug 7, 2008 | 03:25 PM
sjsmal07's Avatar
I'm in the process of installing my dual-poass end plate and associated plumming but I can't seem to remove the intake manifold from the block. I've removed the 7 bolts along with the sensor and dipstick mounts. When I try to pull the manifold off the engine it wiggles a bit on the driver's side but won't budge on the passenger's side. Is there another bolt in there somewhere that the Option B instructions don't show? Otherwise it must simply be stuck... I figured I should see if anyone had found a solution to this before I put a block of wood on top of it and start wailing on it with a hammer.
so... thoughts?
Old Aug 7, 2008 | 03:26 PM
SlowBalt_06's Avatar
theres a bracket on the bottom side to
Old Aug 7, 2008 | 03:31 PM
BlackSS/SC's Avatar
Yup, bracket on the bottom side kinda behind the intake manifold. I think you may have to take off the IC pump to get at it. Don't quote me though, it's been a while.
Old Aug 7, 2008 | 03:35 PM
Steven Flit's Avatar
There is a bolt sitting at the bottom/backside of the intake manifold. You will need to take off your alternator to gain access to it.
If you plan on tinkering with the intake manifold again I wouldn't worry about putting that bolt back in. Makes taking the intake mani out so much easier.
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
