intake mod and engine shut off ?
is this even possible ?
let me explain further im doing like 120 mph i slow down to like 65 "onside" of some and then i go to take off and nothing then i realize the car has died so i pull over and i cant start it....... i reset the pcm by removing the battery terminal, and then it starts WTF ??
i had something similar where i raced to 120mph.... then i drove "hard" around some backroad corners (about 70mph) was spinning the tires a bit and taking some really hard turns.....
then the car just died (lights shut off and all while i was driving at night)....... i rolled for a bit. messed with the ignition, and the car started.
never been able to duplicate the error and i was considering taking it to the dealer. its been 3,000 miles since then and i still dunno what happened.
no in 2.0.................. been reading other post
i must have a clogged cat wierd tho only got 3800 miles on the car but my car has the same same exact probs as the other guy
over 20 psi engine boggs after 4grand cant even push the gas halfway cause then it hits 17psi and makes baaaaaaaad noises
roth
Sep 26, 2015 12:16 PM
