INTENSE is proud to bring you....
Old Mar 3, 2006 | 01:10 PM
  #76
BADZSS06's Avatar
You pretty much got it correct your compression ratio is how much your a/f mixture is compressed. The only Problem i see is with higher compression ratios and more boost there is more of a chance for detination. Which means 93 octane isn't going to cut it after awhile!? Especially with the 10.5 pistons and high boost. i'd be interested to see what happens....
I do know of a alot of peolpe running higher compression ratios and lower boost numbers and making big power in doing so. So someone do the install to see what happens. I would def. consider doing them.
Old Mar 3, 2006 | 01:37 PM
  #77
FAST06SS's Avatar
With the gear spread we have, i think more torque will help us more than anything so that being said. Higher compression and a little less boost will net us more torque.
Old Mar 3, 2006 | 03:22 PM
  #78
jester's Avatar
probably wouldnt hurt to do anything with the injectors if more air is getting in there right?
Old Mar 3, 2006 | 10:22 PM
  #79
KnightRider7900's Avatar
power gain from higher compression is minimal. maybe 1 or 2 ponies per tenth of a compression.
plus higher compression means lower boost, unless u want to blow ur motor.
Old Mar 3, 2006 | 10:40 PM
  #80
dimeo09's Avatar
what is it? haha im kinda new in the tuner world. im guesing cams?
thats a "V-Tec" not cams
Old Mar 3, 2006 | 10:50 PM
  #81
FAST06SS's Avatar
Lower boost = lower outlet temps = less kr = more timing = more dense air charge= more power!
Do some research, it is the new trend!
Old Mar 3, 2006 | 10:58 PM
  #82
zinner's Avatar
Moderator Alumni
You might wanna read the 300 HP LSJ build articles that GMPD wrote. They upped the boost and upped the compression ratio. I doubt they wrote it so people would blow there motors.
Old Mar 4, 2006 | 01:50 AM
  #83
AlphaJaguar5's Avatar
lol, or did they? It is GM after all. j/k Im gonna do as much as in that build book as I can afford
Old Mar 7, 2006 | 12:48 AM
  #84
Tofu's Avatar
bump...any word on price yet?
Old Mar 13, 2006 | 08:23 AM
  #85
Rogue's Avatar
Should be up in our store today. Price will be $699.99.
Old Mar 13, 2006 | 09:03 AM
  #86
R33P3R007's Avatar
360 L337 User
crazyness. What about doing a 10.0/1 piston swap in a stock car. Will that be feasable. For someone going for the sleeper. Or do we need to wait until Conmputer tuning is available for proper gains?
Old Mar 13, 2006 | 09:51 AM
  #87
BLKSS's Avatar
OoOo new pistons. I am NOT looking forward to working on the engine anytime soon unless I have to then I might buy.
Old Apr 25, 2006 | 02:12 AM
  #88
victory_red_SS's Avatar
LSX RWD S/C conversion
BUMP
Okay I need to order these today so are there any updates at all???
Fearedbynone
Apr 14, 2016 03:25 AM
theamericanautos
Canadian North East
Sep 24, 2015 08:11 PM
Tdubbs
Sep 23, 2015 02:55 PM
no_ss
Sep 18, 2015 11:03 AM
